23rd April 2014, 17:28
Hammys Kobra build
After looking around I bought the best donor I could find. Its actually so good Im going to look mad (again) stripping it.
Do any threads on here cover Z3 stripping?
IM really excited about this one and will be building two kits at once as my MEV is still ongoing
EDIT! This no longer the donor as the dealers were shady to say the least. Linky removed
23rd April 2014, 22:00
24th April 2014, 08:59
Pages 2&3 of my build thread have some pictures. I think the basic principle is
Select a panel to remove
Look all around the edges for bolts and screws and remove them
Carefully disconnect and label any wires
Lots of photos of every step to post up here as a strippers guide for the future
eBay the scrap
24th April 2014, 18:02
Hammy one weekend will do it , but you will need a second pair of hands for the bonnet and the soft top , front and rear lights sell really well , also the bonnet , all the best Geoff .
30th April 2014, 15:06
30th April 2014, 17:16
If you don't like the domed side repeaters then I used Ford Transit Connect side repeaters. Available in orange or white.
30th April 2014, 20:51
Any piccys, are they modern led????
30th April 2014, 21:40
Not modern but on the side of my car if you look at the latest pics
1st May 2014, 12:39
wing badges
1st May 2014, 21:26
Now this time, do be careful with the glass won't you!!
2nd May 2014, 07:57
Hello buddy, no glass this time mate!
6th May 2014, 13:13
Brilliant to see the 2 Kobras at Stoneleigh, totally sold on it! Now to finish my MEV and find an alternative Z3 donor
12th May 2014, 13:15
A great mod for the 2.8 is a 325 inlet manifold, it has larger ports and adds significant BHP especially when coupled to a good induction kit like the K&N I fitted this weekend
How much, how easy to do and where from?
12th May 2014, 13:23
Easy to do apparently (mine was done already) and the K&N was ebay £65 the inlet manifold check with a beemer breakers
12th May 2014, 16:40
The air filter is unlikely to add much unless you have an effective CAI.
There are manifolds for sale on eBay. Be careful that you're getting the correct manifold and not being conned with a 323 or 328 one. It's not a straight swap as some pipe work changes and a couple of extra brackets are required. I'll post a useful link later.
The increase in power comes with a decrease in low down torque.
A remap will liberate most benefit with the manifold. All the above together with an M3 exhaust manifold will give you 240bhp.
12th May 2014, 16:50
Correct, I may have been a bit nonchalant there but having modified many engines I call that straightforward for the power increase. Naturally you need CAI but I thought that went without saying.
12th May 2014, 17:02
The remap goes without saying too.
Don't forget that an E34 525 also has the same manifold as the E36 mentioned above.
12th May 2014, 19:58
Right, cool. Maybe Ive made too many assumptions that people would know that. Maybe you could start a separate thread mate??
