28th September 2016, 17:58
COMING SOON :- Triumph based 50's Special.
Although its early days I thought I'd post a pic here to gauge the reaction of like minded enthusiasts to a new product available soon.
The SAMM 10 SPYDER is a Triumph Herald , Vitesse or similar based body conversion to transform your donor vehicle into something resembling the Ferrari's , Lancia's and Maserati's etc. of the 1950's race tracks ...not a replica or direct copy as such , more of a representation of the generic styling of many of these cars from that exciting period ..
Prices and availability to be confirmed but will be available with separate doors and bootlid and a flip style front ... Doors and bootlid can be fixed shut if desired ..
PICTURE OF BODYSHELL BUCK UNDER CONSTRUCTION AND MAY BE SUBJECT TO CHANGE AS WORK PROGRESSES
28th September 2016, 18:29
Given that you're so close, I think you should see if Mark at Southern Triumph Services would be interested in helping with this. No doubt he has numerous possible donors and tons of spares.
Good luck with your new project and belated apologies for not getting back to you about the wheels on the Danish 'D' Type - I had intended to acknowledge your post but it slipped my mind.
28th September 2016, 18:39
Garry
I think "Samm 10" would be a great nick name!
28th September 2016, 18:43
I'VE DEALT WITH MARK SEVERAL TIMES BEFORE HE IS VERY USEFUL ...
The above post was slightly tongue in cheek , but I do have on / off thoughts about producing a new body ..I got lazy and have pidgeon holed it as I was using existing S*mmio bodies to build cars ...if this is now going to be complicated , I need to get the body out of mothballs and continue its development .... A friend of mine who recently retired from the Sunseeker Development and Pattern Making Dept.has been pushing me a bit as he is keen to be involved ..he used to manufacture the original GTD 40 bodies and has done work for various racing teams etc in the past , so its a tragedy not to use his experience ...
The bodyshell was to be called a FORMOSA SPYDER by the way and not a SAMM 10 .. !! ...
28th September 2016, 19:00
...The above post was slightly tongue in cheek , but I do have on / off thoughts about producing a new body...
I firmly believe that if you could combine the styling from the original Sammio Spyder/Cordite with the build approach of the Tribute A352, you would be onto a winner.
I think that was the plan for the "new" Sammio Spyder/Alpha.
As there is a lot to be said for not dismantling the donor car, if it was already "on the road".
( Obviously, complete nut & bolt restorations are a different story. )
Anything that reduces the build time from years to months has got to be a good idea.
28th September 2016, 19:13
I kind of agree Paul ...I am not sure if that is possible now though because I believe Replica Rides built a S*mmio in that way a while back ..left most of the body inside it ...if the idea has been patented , it might be uncertain ground to be treading upon ...I certainly don't want to be drawn into a huge legal battle .... :-) As you say the 'new' S*mmio / Alpha was being created in the same way , but that little car is a long way off being finished , but may well be copyrighted / patented , under a media block or ban ..so best I shut up ...
29th September 2016, 21:51
Good luck with the new venture LL, been a while since I was last on here and there has been a lot happening regards the sammio name ect.....
Me thinks that if you manage to produce a balanced symmetrical shell with the wheel arches in the correct position then it's a winner, I would of thought that this attention to detail will not add to the end costs and give you a car to be proud of plus an easier build compared to what I ended up with.
Looking forward to following this new venture.
1st October 2016, 11:37
Formosa has been on my mind for ages now ....its roughly translated from Italian as ''curvy or flowing lined ''
I have been thinking long and hard about this in the last few days and I have some very definite styling ideas that I have been playing with both in my head , sketching and a bit of mocking up ....I have also been collecting some parts over the last few months but feel now is probably the time to make a start ...
I am not wanting to say too much until there is something to say ...but would be very interested to know what the general opinion is regarding headlights styling ?
Do people prefer the earlier 50's style of 7'' round headlights , Cobra stylee ...or the later shrouded headlight styling like the D type and mid to late 50's Ferraris , Maseratis etc ?
1st October 2016, 12:06
1st October 2016, 12:13
Agreed Towed ..so , reworded ...sharp or blunt preference ?
How about the Formosa Koppeerite ?
1st October 2016, 15:38
Ahh, can't choose between them as I love both looks.
Car Photographer - what are your handling issues?
The suspension setup makes a big difference to the handling on small chassis Triumphs but they can be made to be really grippy and agile, especially with a lightweight body and low centre of gravity.
On mine I've recently raised the front ride height to leave the lower wishbones parallel with the road surface and that really sharpened up the turn-in and steering feel. I'm also running quite a bit of toe in on the rear wheels and toe out on the fronts, and the car changes direction with real enthusiasm and inspires confidence.
Finally, although it's tempting to fit 'uprated' springs and shocks, my feeling is that they're too hard for road use, and 180lb front springs with standard shocks keep the tyres in contact with the road surface where firmer springs and shocks leave them hopping about and losing grip. The same goes for the back end, standard shocks, a couple of leaves taken out of the rear spring and no lowering blocks give better traction and grip than a lower, firmer setup.
As for more modern donors, they tend to be big, heavy and can't be chopped about without going down the (expensive) IVA route. The resultant cars can look really good - I'm a particular fan of Tribute's 250SWB and the 275 is also taking shape nicely, but they can also look awkward, particularly around the windscreen area. I'd rather use the mechanical components from a modern donor and fit them to a purpose built chassis. At least then you don't have to compromise the design to fit around immovable components. I also have a few reservations about access to some service items and systems on the bond-on body panel type kits that are becoming popular with the pay-someone-else-to-build-it customers.
A good example of where I see what I think is an appropriate use of a modern donor would be this classic 'Mini' that uses the MGF as a base-
http://www.speed3automotive.co.uk/models.aspx
1st October 2016, 16:22
new model
Gary,
you have the opportunity to make something special the photograph shows a great front bonnet and the backend i assume a sammio??. One of my all time cars is a very rare ferrari 625trc only 2 made also the maserati models have great shapes 250/300s. if you can get the rounded back end and the bonnet you have with some vents then the shape will be great.
The mention of the locost type route would be good with a few manufacturers out there. An aries motorsport based chassis would be good as this has the narrow track i.e. escort mk2 but you have both live or independent axle.
A guy in america has also completed an mgb based one which would give period style parts wires and cheap parts.
the manual is available with drawings using all mgb parts.
The triumph donor is fine but pricey and the 6 cylinder models are rarer.
regarding the lights as per the maserati flared in.
1st October 2016, 16:29
as for donor cars, I've long thought that repurposing something like the rather fugly Spartan kit car with a new body might be the way to go. Plenty of them around and cheap as they are so fugly. As long as they are registered correctly then it should make a cheap, no IVA needed donor.
2nd October 2016, 08:55
I'v been down this route and still do but it's a bit unpredictable with DVLA.
If your going to go this way make sure you take photos of the donor before you strip it.
Keep the paper work simple, if DVLA don't ask don't tell them.
Also check the chassis number most kits from the 80's and even 90's have there own chassis number. This normally mean the donor has it's own chassis ie; Moss.
DVLA pointed out that if the chassis number relates to a registered manufacturer ie; Triumph Spitfire then the chassis should be an original unmodified example regardless of it's history. which I think is wrong but hey it's DVLA after all.
I have once got around this problem by asking the local Triumph Owners Club to verify (in writing) the chassis was an "original" item.
1st October 2016, 19:12
You always hear about the dreaded 'swing axel' on spitfires, and mine is on such narrow tyres that I'm too scared to take corners at any sort of speed in case I end up in a ditch or worse.
I almost wish I had an identical car to practice on in case anything went wrong,
I do like the idea of taking leaves out of the rear spring though as mine has a very hard ride, presumably because there's less weight in it than on the original spitfire donor,
Is it difficult to do?
1st October 2016, 19:43
I have a mk1 Vitesse chassis under mine so it's on swing axles. With the suspension settings I have I don't suffer any unwanted effects, the car is just too light to trigger the 'tuck under' issues that Beetles, Heralds and pre Swing-spring Spitfires suffered -
The roughly 2" wider track that the wire wheel adaptors give also help stability in corners. Oh, and don't forget that Stirling Moss set a record Mille Miglia time in a Mercedes 300SLR, equipped with swing axles.
As for removing leaves from the rear spring, no, it's not difficult at all. Asuming you don't have a swing-spring at the back (which has a pronounced 'Mexican Hat' shape to the central top cover that clamps the stack to the diff) once you've removed the rear spring all you do is take the nut off the 'peg' that runs down through the centre of the spring stack into a blind hole in the top of the diff and you can just lift off the top three leaves.
Most people then refit the remaining springs and run with that setup. I found that the back end was still a little bouncy for my liking, so I ended up removing one more leaf from the next stack down. They're accessed by undoing the bolts on the two inner clamps (I had to cut mine off), lifting off the next three leaves, removing one of the lower two (the top one is riveted to the clamps) and then refitting the rear spring.
One bit of advice I would give anyone doing this is to Loctite the studs into the diff and use new Nyloc nuts on the top of the studs, otherwise they can work loose, which mine did.
If you get your spring rates, ride height and suspension geometry set right the car should feel light, grippy, agile and very confidence inspiring on the road. Hope that helps.
1st October 2016, 21:26
Cheers, maybe mine isn't that bad, but it feels a bit skittish and I think I'm just too scared to risk pushing it too much (I did write my Boxster off last year pushing it a bit too hard)
1st October 2016, 12:15
nice looking car - could be very interesting
1st October 2016, 12:40
Gary I always liked your revised Spyder, I remember the "german" fronted original.
But I think the sleeker fared in lights, for the Fermosa.
Like this beautiful Bandini.
https://youtu.be/OVdJjgAc6iI
1st October 2016, 12:41
IMHO sharp - with 5" headlights . Covered in preferably but not altogether necessary.
Is there another donor out there not harvested yet to consider ? So many Japanese cars to choose from
How about a ForMicramosa ?
