Ok, the time has come.
Sadly the JNRacing 5EXi-R is up for grabs, as JNRacing is no more.
I am totally gutted to have to sell the car as there has been a load of effort and thousands of hours gone into it to make it that little bit better.
The car is being sold as a powered chassis but there are body designs which can be sold separately to the car. There are a few options on purchasing the car so please pm for details.
The car is a 1 off as it uses only Honda Parts or Marlin supplied/special build components. No Rover! The car was the first EXi to ever have straight drive-shafts and use the Honda Civic Type R as its single donor. The front hubs use the rear spindle off the Civic and have a custom housing and fit inside the original Marlin Carries. Also there is a custom Big Brake Kit designed and made for the car by a leading distributor for AP Racing. The car also has a Race Dyne suspension set-up. There has been no expense spared on this car on safety and mechanical components which is why it is a dream spec car.
Pictures can be found in the Albums 1,2 & 3 on my Bebo Page
www.bebo.com/JC-MotorSport
Specification;
Framework;
Marlin Lightweight RACE Chassis,
Front/Mid/Rear Floor Pan,
All Ali Side/Bulkhead Panels,
Marlin Lower wishbones,
Race Dyne Upper wishbones,
Race Dyne Lower/Upper Pick-Ups,
Gaz Pro Shock Dampers,
500lb Front Springs & Tenders,
600lb Rear Springs & Tenders,
Engine;
Honda Civic Type R, (K20A2)
Custom Race Exhaust System, (106 DBA)
BMC-CDA K20A Induction Kit,
Marlin Race Fuel Tank,
RaceTech Primary Fuel Pump,
Forged Swirl Pot,
RaceTech Secondary Fuel Pump,
RaceTech Power Boost Valve,
Brakes/Wheels
APRacing - CP5060 Calipars, (Pro 5000 6Pot)
APRacing - CP3581 -542CG8, (343mmx32mm)
JNRacing Custom Mounting Brackets,
JNRacing Custom Mounting Bells,
Team Dynamic Pro Race 1.2 Rims, (Gloss Black)
7.5 x 17 Front - E15 Offset,
9.0 x 17 rear - E23 Offset,
GoodYear Eagle F1 DSG 3 Tyres,
215/45/17 Front,
235/45/17 Rear,
Interior;
Marlin Wiring Loom, (with dash mounted switch panel)
Marlin Quick Race Steering Rack,
JNRacing Steering Column,
Corbeau Pro Series Seat, (Carbon/Kevlar-Standard)
Luke Roll bar Mounted Harness, (5-Point 3x3)
Mono Boss Kit,
Snap-Off Quick Release Kit,
Sparco Extreme Race Steering Wheel, (310x270)
Exterior;
Carbon Effect MotorSport Wing Mirrors,
SVC LED Brake & Indicator Rear Lights,
206 Angle Eye Headlights (Black) or GTi Headlights,
Clear Side Repeaters,
BODY!!
THE BODY IS MY DESIGN AND HAS A PAINTENT ON IT. THE NEW OWNER OF THE CAR MAY PURCHASE THIS BODY AND THE MOULDS IF THEY SO WISH. THE BODY WILL TAKE 12 WEEKS TO BE MADE AND WILL BE FITTED DIRECT TO THE CAR.
PRICE!!
I have no set price for the car but please make sensible offers. I have receipts which total to over 22K not including all the little bits and pieces so grab yourself a bargain.
PM me for more details or any queries,
Jon Coombes
marlin_v8_looney@hotmail.com
