Old 22nd August 2005, 09:12
Default Heater Control Cables
I've just spoken to Rover. They can't sell me the cables as a separate item! So, does anyone have a source for these?
In the meantime I'll try my local scrapyard.
I need the two longest of the set...
Old 22nd August 2005, 09:22
Bennyh Bennyh is offline
Bennyh is on a distinguished road
Hi m8 I just had the same problem. I went to my local scrappys to pick mine up they all seem to be the same for the 200/400 new and old shapes. I payed 2 squid for the set. Good Luck
Benny
Old 22nd August 2005, 16:13
tony-g tony-g is offline
tony-g is on a distinguished road
hi
what i did for my last car was i used the plastic covered wire that is used for hanging net curtains for the outer and for the inner most radio controled modle aircraft shops sell the wire in metre lengths so you can make them up your self. Also sierra bonnet release cable is very good for the outer cable.
all the best
tony-g
Old 22nd August 2005, 16:30
Benny,
I've put an enquiry into the local scrappie, should find out tomorrow.
Tony,
A cracking post mate, many thanks.
John.
Old 22nd August 2005, 20:13
limpabit's Avatar
limpabit limpabit is offline
I have the same problem. Only had the green ones. But I think it's the yellow one which is longer. When I emailed Marlin about where to get them from, they said you can get them from them.
Hope that helps.
Old 10th September 2005, 18:21
tomboysexi tomboysexi is offline
tomboysexi is on a distinguished road
Default Another solution
Hi everyone.
We solved this one by using the outer from an old accelerator cable and a wire inner from a model shop.
Best thing is you can make em as long as you like and it works so well
Regards to all builders.
Trev
