Old 1st May 2009, 21:02
mynameisjon21 mynameisjon21 is offline
mynameisjon21 is on a distinguished road
Default Random red wire :help:
Hello
Firstly hello everyone
I have encountered a problem building my Kit car :-( it is probarbly a really easy fix too
I am hoping to start my engine for the first time in about five years tommorrow but have a wire that is attached just below the carb (the anti dieselling valve?, just above the inlet manifold) it is red and isnt connected to anything else.
What does it connect too?
there is a black wire going to the side of the engine which is the temp sensor so its not that, i think it is the anti dieselling vavle which i presume would be connected to the ignition wire? but im really unsure
My engine is from a c reg sierra ohc and is a 1.6
Thankyou in advance for your help
Old 1st May 2009, 21:12
martin butler martin butler is offline
Kit Car Dreamer
martin butler is on a distinguished road
i used to have a sierra 1,6 it might be the electric choke , on my old car there was a choke heater inbetween the manifold and carb , with a singe wire going to to the ignition switch i think it was a ford vv carb , but not sure, it was a long time ago hope this helps
Old 1st May 2009, 21:35
cheers for the quick reply
this was one of my other thoughts, would this wire be live all the time when the ignition is on? if so would it over heat or does it not matter??
Ta
Old 2nd May 2009, 21:20
Kit Car Dreamer
i should think that there would be a bimetal cut out in the choke element that cuts the supply once it has warmed up ,or somewhere in the loom if it was constant, the wire would burn out
Old 3rd May 2009, 14:24
After closer inspection it appears to be a pipe/tube, the same diameter as a wire (hence the confusion)
ive attached a pic :-)
cheers for all your help
