8th June 2012, 07:35
Tribute Mx250 build progress.
Hello,
My name is Billy and this is my first time running a thread so go steady on me!
I will be posting my build step by step inc photo's over the next month. I have a 3/4 day slot booked at my freinds paint booth at the end of the month so it has to be ready for then.
Cheers Billy
9th June 2012, 14:59
Looks like you're trailblazing! good luck matey and lets see loads of photos
9th June 2012, 16:17
Hi Dave,
I am starting a new post in the new tribute section tonight.
Cheers dude
9th June 2012, 17:49
The donor, mk1 R reg 1.6 16v one owner. The tribute roll bar fitted! (with ease) I know i should of sprayed it before fitting but i was eager to get started and quite like the grey primer colour ha.
9th June 2012, 18:22
the rear trimmed and ready to go!
9th June 2012, 18:24
Roll bar fitted and both kit mounting panels.
9th June 2012, 18:26
the rear dry fitted, i thought i was going mad as could not get it to sits level, then noticed a knackard spring! hence sitting low at one side! new springs enroute!
9th June 2012, 18:29
dry fit front end, hardly any trimming needed, hugs the car well.
9th June 2012, 18:30
hmmm should of moved the lump hammer! it was not used to fit the kit!! honest!!
9th June 2012, 18:33
I filled the arches with expanding foam, it has made it very solid.
9th June 2012, 18:37
The roof married up perfect. NOTE, filled with epoxy R-KEM (rawl fixings) sets rock solid to avoid cracking.
9th June 2012, 18:48
I have used the MX5 head lights, fitted the fixing ring to the inside of the shell (fixed 6mm threaded rod with the k-rem fixing resin then fitted the head light frame so that they can be adjusted by moving the nuts. The light frame sits proud of the body and i think it looks grand, I also cut the side light fixing out of the mx5 side lights and carefully drilled a hole inthe head light bowl and bonded on the side light fixing. So now i have the side lights in the head lights and another plus is that all original wiring (plugs/fittings) and makes life easier. (pics of side lights to come)
9th June 2012, 18:49
9th June 2012, 18:50
alittle sanding to do but other than that...job done.
9th June 2012, 18:51
9th June 2012, 18:55
Holes in the bonnet for the wipers. I cut some wiper legs from a scrap car and slid alloy tube over them and held in place with rol pins (so can be removed without to much hassle)
9th June 2012, 18:56
I have milled some alloy gromets to fit once painted..but im sure some rubber ones would do.
9th June 2012, 18:58
does anybody know what crome/stainless wipers would fit the mx5?
9th June 2012, 19:19
9th June 2012, 20:01
Photo of back of the head light, I cut the plastic side light fixing from the side light/indicator lense and bonded it to the rear of the head light. Make sure to totally seal the joint otherwise the lamp will mist up. this saves having to have a ugly side light elsewhere that in my opinion would spoil the lines of the car & its using OEM fittings and saves cutting wires etc and best of all its FREE.
