ok so I do fancy a coupe but need to think glass first VW beetle 1303 has a curved screen but I think it will be to high. shame I can get a full set of stock glass flat screen for £70 not to far away. Morris minor back window looks more in proportion easy to get just need to find one I can measure. MGB frame with glass but I think to straight.side and rear not so much a problem its getting the front right so any others I could look at.
split screen still has a curve on the edges so would it still work with just flat glass and look as good
loving the flat bonnet look too but dont think it would cover the engine big bump with a vent maybe now that would spark questions lol
yep they are still trading Gary is whom the part body came from. I was going to pop down and see some of his kits to give me a idea of which way to go see one in the flesh. Not a big fan of the removable hard top just always look like an add on.with a coupe same as in the 250swb the lid makes a massive difference and is what makes the car so cool. decision decisions
meet jedward lol work in progress made a right mess of my garage hope fully get some fiberglass on it tomorrow see how its looks
thanks for the positive comments Mr t, I am not trying to copy anything going very much by eye and what I think will look right. The proof will be when I get some fiber glass on it and open the windows up . that's today's job front screens will be flat glass. In fact I have planed it right it will all be flat glass so that will make windows easy.
Not every day you plaster a car but I fingered it was going to be the essayist way to fill and smooth things out
I then covered everything in tin foil so touch wood 90% should come off without to much trouble
I used 300g csm then 3mm core mat two more 300 then topped just the middle with 600 csm hopefully it should give me enough strength. if not I will add more after I cut it back .
it should be thick enough to cut back around the windows I will then gel coat the lot. I will also fill in the inside of the A post and put a top on the B post
least I can make the B post on the bench and just glass it in,Most of it had set by the time I packed up I had to resist the temptation to cut the windows out and start removing the inner support.
And we have a roof considering I only did it yesterday it seems rock solid as it cures it can only get better. Next job cut it back fit A&B post then gel coat blend it all in. windows to trim back and make a cut the templates for glass
hopefully when the plaster is dry a good thump on the roof most of it should fall off if not that,s going to be a bugger to clean off
Mitchelkitman ,,,,plaster is just a multi Finnish but any finishing plaster will do the same job. No wax dose not need on tin foil. top tip put a hand full of cement in the plaster makes it set quick saves you waiting around for ages. dont over do the cement it will set before you know it
thank you we all need a push sometimes knowing others like what I am doing keeps me going.
Jedward is starting to look the part the roof smoothed out bloody good even if I do say so myself.
I changed the back window to two as the curve on the roof wasn't going to work with plate glass.
started on the inside putting an inner on the roof so its not just a skin all the widows need trimming back and the dash is going to get changed.
hard work trying to glass on the in side of the roof with strong winds blowing though the car .another few days work on the outside could see some primmer on the car that will transform it. I am starting to thinking about bumpers yes or no
I made the mistake of using glue to hold it on the plaster in places so were they is glue it stuck it dose peel off with work. No glue no it will not stick when dry it will peel off.
what a difference a bit of primmer makes it shows I have loads of tweaking filling and sanding yet again. still getting there sweet but yar
