9th July 2021, 18:11
Car struggling to start and running rough when warm
I drove the Z300S for the first time in several weeks. Everything was fine until after parking outside the shop I went to start and drive away. It didn't start easy with plenty of churning before it sort of gasped into life. When I pulled away it was powerless and felt like it was running on 3 cylinders.
Gentle throttle produced better results than heavy throttle. If I stepped too hard on the throttle it stutters and the revs dropped. With gentle throttle I could coax it up to 30-40mph.
After a few minutes it seemed to clear its throat and was back to normal with no bad signs at all.
I am sticking a new air filter on it because it needs one but anything else you guys can think of to look at?
9th July 2021, 19:17
Didn't you have an issue with the inlet manifold and associated parts a few years ago ? Might be an air leak is messing the fueling up in that area ?
10th July 2021, 07:18
Try unplugging the MAF and see if it makes any difference.
The air intake pipes do fail with age worth giving then the once over.
Did the engine light come on? Always worth putting a code reader on to see if there ant codes showing.
10th July 2021, 08:39
No engine lights. Air intake is my guess. I have a butchered set of pipes where I fitted a 2.5 intake to a 2.8 engine to get better breathing.
i just wanted to check if there was anything else obvious I migt have missed.
10th July 2021, 10:26
If it happened all of a sudden rather than gradual deterioration chances are something has become detached or broken.
10th July 2021, 10:45
Only other common culprit is the cam shaft sensor, doesn't always set the EML light up but should show on a cide reader.
If you don't have a code reader, you can get them on eBay for about £15. I find my £15 reader better than my £200 Foxwell.
11th July 2021, 09:03
It is hard to tell whether it was gradual or sudden as I don't normally use it for stop, start journeys. I remember it being a bit spluttery on start up a while back and I can remember one time it seemed down on power so I am guessing at gradual.
If the rain holds off I shall stick the new ait filter on, take it out for a blast, come home and then try and find the issue assumingthe air filter doesn't fix it.
I shall probably buy some fresh gaffer tape and some zip ties to ensure the repair holds. :-)
11th July 2021, 15:59
The Gaffer tape might be going a bit crusty since the LeMans temporary fix !
11th July 2021, 16:41
I added a spare zip tie a couple of years ago to keepo the LeMans fix up to spec, don't worry...
11th July 2021, 16:43
That's alright then, I was beginning to worry !
22nd July 2021, 11:22
Found the leak and now just need to fashion a repair
22nd July 2021, 14:45
Did you stab that with the screwdriver or are you showing us where the hole is ? Swop those parts out for some new silicone hose or BMW parts maybe ?
23rd July 2021, 09:19
Screwdriver is there to show the split.
Standard BMW parts do not fit because it is a 2.5 intake manifold on a 2.8 head and the hoses are different. Hence the gaffer taped version that has died.
The 2 pipes not impaled by a screwdriver are the nearest I can get. A silicon alternative would be preferable but there is a slight bend and that little pipe coming out the side which means I can't get one.
Managed to bodge one together with one of the two good pipes and some bicycle innertube glued over. This got the engine running but I will not remove and improve at the weekend.
23rd July 2021, 09:47
Can you get a flexible rubber thread for your 3D printer?
23rd July 2021, 10:22
I got bored of the 3D printer and sold it. It took too long to produce anything useful and it was easier to get a proper 3D printing company to do stuff. It would have taken about 40-50 hours to print something the size of the pipe and probably longer to ensure it was airtight and with a special filament.
23rd July 2021, 10:49
Is there no adhesive that will join the rubber successfully?
Bailwick used to sell replacement CV joint boots- no dismantling required, they were supplied split and with a "superglue" to stick them together. It worked well enough under those constantly flexing conditions to be commercially viable.
23rd July 2021, 10:59
Look in the picture. There is a tin of it. I am using the innertube to re-enforce the bond, almost like a puncture repair kit. The challenge is that the gaffer taped on that originally worked is two hoses cut and taped together and now the rubber has perished too much so there are cracks all around the neck of the pipes. Needs new hoses which is sort of what I have made.
Out of interest, will running the car with the MAF plug unplugged do any harm? Car runs lovely without it but a bit spluttery with it. I am looking for a hole but Google suggests that MAF failure is quite common and expensive to fix. Removing the plug seems a cheap and easy solution.
23rd July 2021, 11:36
Self amalgamating tape might be useful.
Without the MAF connected, a default mixture map is used. My 2.8 runs fine without it but the emissions test at MOT time will need it reconnected.
27th July 2021, 21:41
It ain't pretty but it works with the MAF connected now.
28th July 2021, 07:02
Bodger alert!
If you know what car the pipe came from you will be able to track it down on
https://www.realoem.com
You will then get the part number that you can put into eBay or Google.
Not sure about BMW but Mercedes have the part number printed on almost every part, makes getting replacement parts much easier.
