Old 16th July 2019, 16:11
pippip pippip is offline
pippip is on a distinguished road
Default Sportster Throttle Cable
Can anyone help me work out how to refit a throttle cable on. Sportster Mine snapped today at the pedal end and the spring fell off so I have no idea how it fits onto the cable. I am waiting for a new cable from Car Builders Solutions but have been trying to work out with the old cable how to replace the spring. Just my luck just this morning booked onto the Silverstone classic Weekend Incl the Retro Run and now no throttle, There is nobody at The Marlin factory until next Monday and then its pot luck if they answer the phone. Anyone got one similar they could describe how it fits. Thanks. Pip
Old 16th July 2019, 20:16
MartinClan's Avatar
I am afraid you will find most builders did there own thing with the throttle cable. What pedal box and engine do you have.? That information may help someone, with a similar configuration, provide an answer.
Cheers Robin
Old 16th July 2019, 21:37
It's a factory built car with a BMW engine
Old 18th July 2019, 17:24
MartinClan's Avatar
On my E30 based sportster I was able to reuse a BMW throttle cable. The return spring at the pedal end however was a different story. There was no provision in the Marlin pedal box so I had to invent something. Can't remember what I did now and the car now has a new owner so unable to look for you. Sorry. I am sure someone else will volunteer an answer.
Cheers Robin
Old 18th July 2019, 18:17
Ok thanks Terry at Marlin is looking into it for me I have roughed up a temp solution with twin return springs and a universal cable. Fingers crossed it lasts until I can find the correct cable
Old 20th July 2019, 11:51
Patrick's Avatar
Patrick Patrick is offline
On my E30 based sportster I didn't use a spring at the pedal end. I held the cable in to the notch on the pedal using a stainless pipe clamp with a notch for the cable pass by.
Old 20th July 2019, 11:56
Ok understood but where did you locate a return spring?
Old 20th July 2019, 12:30
Patrick's Avatar
I found the spring built into the throttle body sufficient. I like a nice light pedal for the throttle.
Old 20th July 2019, 16:00
Ok thanks I will give that a try
