Old 20th January 2019, 19:02
ian roberts ian roberts is offline
ian roberts is on a distinguished road
Default 3mm hole in fuel tank
Guys I have an aluminium fuel tank, it has a 3mm hole with a self tapping screw with some kind of mastic over it as a stopper. I want to do the job better. Any ideas ?
Thanks Ian
Old 21st January 2019, 10:13
Drain the tank.
Remove the tank.
Displace the fumes by filling with water until it over flows.
Repeat four times.
Dry the tank out.
Weld up the hole.
Pressure test tank.
Refit.
Best to take it to a professional and they will make sure it is done correctly.
Old 23rd January 2019, 13:44
Darkspeed Darkspeed is offline
Darkspeed is on a distinguished road
Blind pop rivet with sealer under the flange
Alloy Rivnut, flange head bolt with cork washer
Weld.
Old 25th January 2019, 07:53
now welded up guys
cheers ian
Old 25th January 2019, 18:54
molleur molleur is offline
Properly done, good!
