6th July 2016, 19:45
250 swb build
I was approached via Jeff H on here to put a 250 SWB together for a guy that had started the build but come up against a brick wall . He went to see Jeff's car with a view to building some similar features to Jeffs into his and , long story short ..I have the build .
Jeff will be doing prep and paint , I have been asked to fit the kit and incorporate a few changes ...
The customer had fitted the front end , placed the rear section on but not fitted , wired the rear lights in , fitted grille and plates and door frames ...and drove it 65 miles to my workshop !!
I made a start yesterday ..
I have fabricated from ally sections , some rain channels to go around the bonnet aperture .. these are bonded , rivetted and fibreglassed in place .
I have done the inner wing slice both sides , I chose the two slice method and glassed it back together .
I have removed the original BMW wing mounts ..
Washer jets and side repeaters have been trial fitted .
I have begun to fit hidden fixings to hold the bonnet in place , simple homemade 'bighead' style fixings using flat plate and 8mm bolts welded in the centres , bonded to the underside with tiger seal ...
I have also removed the doors and interior in preperation for the shorter door / higher cill modification that this ones getting too ...
6th July 2016, 20:06
I'm not sure how well it shows in the picture , but the front rain gutter has 2 ovalish dips to allow the bonnet pins to locate fully back in their holes .
I ended the day with seats and rear carpet section removed . Drivers seat came out in about 10 mins ...passenger seat about an hour ! The electric motor stopped working , so I couldnt get to the rear bolts that hold the seat in ...after messing about trying lots of different things , I phoned Chris at Tribute to see if there was an easy way ...Chris basically said , you are screwed ! but if you can get the cables on either side of the motor to turn , you can very slowly wind the seat forward manually ...the cables turned ! so that was cool ...I decided to cut the cables , put the cut end in a cordless drill and wind them that way ...it worked !!
7th July 2016, 08:27
Door/sill mod
I do like the look of the modified door and sill but it looks like an awful lot of work. Could anybody do a photoshop of the rear of the door being curved and the rear wing / sill gap being filled but leaving the bottom of the door and sill itself alone?
7th July 2016, 16:24
The more different build threads the better. I am watching your thread and Jeff's avidly along with JagTVR's.
7th July 2016, 18:18
Managed to get 4 hours in on the car today .
The bonnet pins I made yesterday had cured overnight , so a quick clean up and my nylon spacer added with a washer and the bonnet was ready to fit.
(Luckily whilst I was in Wicks yesterday I spotted that they had put the 250 SWB bonnet spacers they sell in the wrong aisle and they were in the 'door stops' category and priced at 49p a pair !!)
I drilled holes in the fixing plates to allow the tiger seal to bleed through and grab the bracket better ...
rest of the afternoon was spent mostly removing stuff ...rear bumper and all its bracketry in preperation for a Jeff H rear framework to be fitted.
seat belt mounts were cut off as this ones getting a harness bar ..I welded 4 ringbolt seat belt mounts into the car as well ...2 on inner cill where a handy grommet lives and two on the rear of the tunnel...
final job of the day was to remove the passenger side boot hinge ...
more tomorrow ...
7th July 2016, 19:27
Thank you for doing this thread. Some useful information and good photographs!
7th July 2016, 19:42
Hmmmmmm are you just fuelling the curiosity?
9th July 2016, 06:14
Gary - Love the use of door stops.
9th July 2016, 19:36
Not much achieved today as I had my son to look after this morning and had some parts chasing to do ...
I have now got this section ...
I'm fitting the filler cap in the 250 GTO location , which has me a little perplexed at the moment trying to find a solution to the new placement and the route the fill tube can take to enter the tank nicely , no kinks , not too slow a fill etc...I've got a rough idea how its going to work but until I start digging , not totally sure ...
The boot corner piece Chris at Tribute supplied is a good starting point , the cap needs to be recessed slightly , reducing the flow angle , but I think we can make it happen ...
I finished the hinge movement earlier , rebraced it and checked for operation ...so not much achieved today , hoping to get a few hours on it tomorrow as I only have a certain amount of time to get this car ready for the paintshop ...
9th July 2016, 21:13
Is the filler going in the LHS? If so is it possible to turn the tank 180 degrees to improve the fill route? (might make it difficult for exit tubes on tank though?)
Just a thought.
10th July 2016, 16:32
Managed to get 3.5 hours in on her today ....
Jeffs old filler recess he decided not to use on his car was a godsend today ...Combining trimming it down in height and a section of MX250 acquired from Tribute , enabled me to do this ....
All held together with straps and tec screws for now .. a section of the SWB boot aperture was cut away and the MX panel grafted in ...the rain channels and a bit of bodywork will need fettling but I managed to get the rear back off , turned over and glassed up before I left.
The reference pics I found show the cap on close inspection to not be fully flush as I first thought , but to actually stick out a little bit ...
The cap supplied is a bit larger than the originals , so will dominate this area a bit more than they normally do , but its minimal really and once all the edges are straightened out , gapped around the cap etc..she should be good to go ...
When I put it back on , I can start the bootlid mod. and then the task of connecting to the tank begins ......
10th July 2016, 17:10
Thanks Jeffy baby .... I used these two images ...
http://www.boldride.com/ride/1960/fe...netta/image/26
http://www.boldride.com/ride/1960/fe...netta/image/27
If you take the image number bit off the end of the adress , it links to a great gallery ...
Its interesting because looking at your pic above , I would have opted to put the cap hinge above the shut line ..a few pics suggest that , but my links show it inline with the shut line ...I know they all have subtle differences , no 2 are quite the same ...and that is great news for the fakers !!
10th July 2016, 17:29
Originally Posted by Jeff H
The filler will be mounted LHS,
This is what the customer has asked for, it will be a challenge to get the pipes routed across to the offside, the customer is fully aware it may be a slow fill but he is happy for the trade off.
Gary picked up my old filler recess this morning to use, he is so keen he is working on it on a Sunday .
So not possible to turn the tank 180 degrees so the filler can be on the same side?
11th July 2016, 06:29
Gary - So far, it does look like this…
Is going to make a good tribute to this.
Is there any way of fitting a different petrol tank in the current space?
Something similar to Oxford's Sammio, but bigger, just to make the fuel hose route easier.
I've only just started using those straps on my own build and they are great for this kind of thing.
11th July 2016, 06:51
It might be easier to modify the tank cut a new inlet and patch the old
11th July 2016, 18:31
ROADSTER - Yes mate , thats one option I am considering ...
PAUL L - I wanted the customer to fit a new tank in the boot , thats actually how the 250 SWB is ..but he wants to retain bootspace as much as possible , even creating some extra space if we can ...
Today I continued to beaver away on the fuel cap mod ...
We are at this stage now ...
I have modified the boot inner skin as well , moved the original hinge mount in to match the hinge and re-instated the inner rib to flow better with the new location ...its only roughly filled so far , another bit of filling required to straighten it out a bit , but you get the idea ...
So at the end of today , we are at this point ...it still needs gapping up a bit , but thats Jeff's dept . !!
tomorrow I go digging and hopefully find a solution to the fuel flow ...
11th July 2016, 18:49
I know its a lot of work but I much prefer this fuel cap location
11th July 2016, 19:32
That represents about a day and a half ...but agreed , it does look cool ...if a builder opted for the tank in the boot option , its a lot easier to create ...
http://www.boldride.com/ride/1960/fe...netta/image/41
12th July 2016, 07:59
Superb work!
Dont fancy taking a mould off of that area do you, for those who have the inclination but not the skills!
12th July 2016, 18:52
Originally Posted by Very Andy
Superb work!
Thank you ...How much would you mould ? at some point you need to join it into the standard kit ...I wouldn't want to start moulding one of Chris's kits . But Chris has been known to deviate , perhaps have a chat with him ?
I worked out the filler tube today , no pics as its all apart again to be welded and bracketry added etc.. but it basically comes from the original filler and back on itself through the panel next to the filler at about the 10 o'clock position ...this puts a piece of 2'' stainless pipe sticking into the rear shelf area next to the rollbar... it travels through the rear boot panel into the boot area ....it will be a slow fill but its a constant run ...
