Old 3rd May 2016, 18:48
mcramsay mcramsay is offline
Default mirrors
Can any one reccomend some nice wing and rear view mirrors for the sportster that are iva proof and look the part?
Old 4th May 2016, 20:10
morris's Avatar
morris morris is offline
All I can say is don't buy the ones I have (which is not quite the answer you want I know)
http://www.s-v-c.co.uk/product/ital-door-mirrors/
and
http://www.s-v-c.co.uk/product/rear-...inless-steel-/
The wing mirrors look nice and met the size for IVA but the NS one was impossible to position correctly for the required viewing angles. They also don't move position very smoothly. I had to make up a nasty wedge block to tilt it inwards. Go for something with a decent length arm on it and plenty of movement.
For the rear view, again the area was fine but it was a bit short and only just scraped through plus I had to plaster it in rubber trim and some monster sized heat shrink to get it past the radius test.
I'd buy for the IVA now and pick for the look you want later and not worry about the extra holes you'll have to fill in the body
Old 4th May 2016, 20:23
Good advice as always! I have plenty of holes to fill so a few more doesn't bother me. There are some nice ac cobra iva friendly ones on Europa. But they are pretty expensive.
My list of jobs is slowly going down. I might just make iva before the summer, with a long failure list!!!
Old 4th May 2016, 21:37
phil.coyle phil.coyle is offline
phil.coyle is on a distinguished road
If you have wing mirrors why do you need a rear view mirror as well? No white van man has an interior mirror if the van has a panel behind the driver.
Surely the wing mirrors are rear view mirrors, or am I missing something here, like a brain?
Old 5th May 2016, 10:00
morris's Avatar
I'm pretty sure that the rules say that if you have a view to the rear, you must have the mirror. This is how vans get away with it, there's nothing to see
Old 5th May 2016, 10:07
Mike Mike is offline
I had a similar experience to Ian - my external mirrors are these:
http://www.s-v-c.co.uk/product/lucas...-wing-mirrors/
They passed the IVA - but were marginal for size, and ability to focus on the zone required in IVA.
In use they are very small compared to what we are now used to on modern cars, and dare I say I feel are dangerous due to the very limited area of vision they provide. I would like much bigger ones from a safety perspective.... but what modern mirrors would look right?
I used a modern Ford Fiesta rear view mirror - totally IVA friendly, easy to stick on the screen with a double sided pad, a good size for continued use, and cheap to buy. It has remained on my Cabrio and works well.
Old 7th May 2016, 13:11
Thanks for the replies. I think I might spend the money and get ones that look good and are good for iva aswell!
Old 7th May 2016, 19:22
MartinClan's Avatar
Try Tex Automotive. They supply a huge range of mirror heads and arms that you can mix and match. Convex glass for a wide view. SvA freindly ( mine passed without comment) and made in the UK.
Old 7th May 2016, 19:23
Thanks for the suggestion, I will check them out
Old 10th May 2016, 16:20
6981marlin 6981marlin is offline
6981marlin is on a distinguished road
Default Mirrors
I got mine from CBS and they went through the iva ok last week. Will dig out the item number when I get back if it helps?
Old 10th May 2016, 17:08
Yes please if possible
Old 10th May 2016, 20:37
Patrick's Avatar
Patrick Patrick is offline
I ended up using some plastic ones with taped on convex glass to pass (SVA at the time). I put chrome bullet mirrors, also convex on afterwards. This silly thing it for field of view the bullet mirrors would have passed, but not for glass area :/
Old 11th May 2016, 18:17
Default Mirrors
I can't find the item number, but I will try to attach photo of current mirrors.
Ryan
