Go Back   Madabout Kitcars Forum > For Sale / Wanted > Cars and Parts for sale, swap or wanted
Cars and Parts for sale, swap or wanted Cars, finished or in various states of undress, parts, swaps and wanted. Post here for Free
Old 22nd April 2016, 11:37
morris's Avatar
morris morris is offline
Default various bits n bobs
Hi,
I've a number of parts left over from my Marlin Sportster build. See list below. I thought I'd offer up here before sticking it all on ebay. PM me if you're interested.
Ian
- VDO Vision Clock 52mm - has seen 150 miles in the car since IVA so in like new condition but as I'm disconnecting my battery when not in use, I don't want to set the time every time I use it. Same version as HERE - £50 + P&P
- Pair of Stainless Spot / Driving lamps - Again only seen ~ 150 miles since IVA so like new. I bought them for full beam without realising the main lamps I'd ordered had sides, head and main in a single unit so they are just dead weight and a power drain for me. Same as these units HERE - £50 + P&P
- Pair of Ali Steering rack extenders 50mm each with 25mm of thread. M14x2.0 thread inside and out as with THESE but in black - £10 +P&P
- H&R Wheel Spacers DRA40 (part nr 40757252) total track widening is 40mm i.e. 20mm each. PCD is 120x5 with centres 72.5mm. These are designed for BMW E36/E46. There were only used while building and IVA'ing the car and were then replaced with DRA80 so show some signs of wear from being taken on and off the vehicle but are essentially as good as new. Same as HERE - £50 +P&P
Old 29th April 2017, 20:44
morris's Avatar
The above items are still available. I also have some more to add to the list
Wilabb 1.5ltr header tank 2x8mm and 1x23mm ports - £30 + p+p - SOLD
https://flic.kr/p/bAbUuW
Obp 1ltr fuel swirl pot 3x9mm and 1x12mm ports - £30 + p+p - SOLD
https://flic.kr/p/c3Fe5Y
Pacet 12" pusher fan 11 blade - £50 + p+p
https://flic.kr/p/difuwh
All these parts have been used for getting my sportster through iva and the 800 miles of its first year on the road so are in good condition. I'm just rearranging my engine bay so making some modifications and these parts are no longer needed. P+p at cost
Pm me if you're interested or want to make an offer
Cheers ian
Old 25th May 2017, 07:40
Nickycross1985 Nickycross1985 is offline
Nickycross1985 is on a distinguished road
Default What is this
Hey wonder if anyone can help me my ex has left this mine and having a clear out wondering if worth anything and if it has all its parts
Old 30th May 2017, 12:15
pompeyal's Avatar
pompeyal pompeyal is offline
pompeyal is on a distinguished road
Hmm I have been locked out at looking at your pictures, don't know why?
Old 31st May 2017, 16:52
pompeyal's Avatar
Hi, its a HID headlight conversion kit and looks all there, look around on EBay some of these kits a dearer than others (From £65), I am sure if you don't require them someone on here would like to have them, has the kit got the bulb type info because you will need that to compare what you may have.
