Old 11th April 2016, 20:52
MartinClan's Avatar
Default E30 325 alternator
My alternator has gone phut. The 325 alternators are pretty expensive. Does anyone know if I can fit one from another engine, 318 or320 perhaps, without any mods. I dont need the stonking 90amps that the 325 alternator provides.
Cheers, Robin
Old 11th April 2016, 21:36
phil.coyle phil.coyle is offline
phil.coyle is on a distinguished road
It may be the regulator or the diode pack, you can replace them yourself. Try www.jcrsupplies.co.uk for spare parts.
Old 12th April 2016, 18:37
morris's Avatar
morris morris is offline
Robin,
Take a look at my build log on Flickr
https://www.flickr.com/photos/580680...n/photostream/
I've just successfully got a light weight denso alternator running on my sportster. It cost about £90 plus another 20 odd for a light weight ali 6V pulley. It did require a bit of bracket fabrication so that may put you off
Old 13th April 2016, 08:53
MartinClan's Avatar
Thanks Morris
That Denso alternator does look good, but I want to do the job with the minimum of hasssle so I think I will stick to an "original".
I finally found a remanufactured one on ebay (From a 320 but I think that just means its 60A raher than 90A). And at least it has been remanufactured by the supplier so I can always shout at them if it is no good :-)
Cheers, Robin
