Old 25th September 2015, 15:28
Rene Rene is offline
Rene is on a distinguished road
Default 274 in restoring
Hi Champs
Frame now welded and restored with new outriders looking as should be, just perfect.
Regards
Rene
Old 27th September 2015, 08:13
Rene - Glad to hear the chassis has been sorted out.
Is there any other work to do, or can it now be put back together?
Old 27th September 2015, 09:00
Paul, there are some other issues to do. Gear change,
Footwall driverside welding, electronical modifications distributor missing?. But after coating the chassis, will start to put together the suspension,brakepipes e.t.c...
Regards
Rene
Old 27th September 2015, 12:45
micky1mo's Avatar
micky1mo micky1mo is offline
Hi Rene, I was just looking at the chassis of 274 before it was stripped and noticed the rear leaf spring is the original Herald one.
These are designed to carry a much heaver body so make the ride in a Sammio very hard.
You can remove a few leafs but I have a Spitfire rear spring with a lowering block fitted to my BMW powered Sammio and the ride is quite reasonable.
Old 27th September 2015, 14:28
Thanks for your info. I will check this. I am thinking also to modify with a stabilisator at the rear....
Regards
Rene
