Old 26th February 2006, 20:29
Patrick's Avatar
Patrick Patrick is offline
Default Fuel pipe to tank
What is the best way to attach fuel pipe to the tank? Im using 8mm black pipe.
Old 27th February 2006, 20:26
Patrick's Avatar
I've ordered some of these:
And an NPT 1/8" tap off eBay so hopefully that will do it!
Old 8th March 2006, 19:14
Patrick's Avatar
What is the best stuff to seal/hold these types of connectors to the tank? (holes are tapped)
Old 24th March 2006, 19:51
Stuart Stuart is offline
Stuart is on a distinguished road
Patrick where did you get these ive been looking for them for ages as the return to my tank is very close to the diff and the fuel pipe fouls it when fitted. The right angled conector would solve the problem. I would fit these with some locktight 275 as this is liquid & gas tight so should be good for petrol. I will test some in petrol over the weekend to see if its ok.
Old 29th March 2006, 13:28
Patrick's Avatar
My post seems to have gotten lost I got them either at www.rallydesign.co.uk or www.europaspares.com. You can also get them at KMS and http://www.raceparts-direct.com/
