Old 28th August 2014, 06:36
w3526602 w3526602 is offline
w3526602 is on a distinguished road
Default Need short wiper arms and blades.
Hi,
This is a query about my 1959 Land Rover, but as I am rebuilding onto a new chassis, there is a sort of kit car association.
The early land Rovers had one motor per wiper, fitted close under the screen. Later Land Rovers used cable drive to wheel boxes, which were fitted lower down. There is about two inches difference in the length of ARM+BLADE .... two much to "bend out". Early arms and blades are virtually NLA.
I need an arm + blade with an overal length of 36cm (call it 14"). I was wondering if a 2CV would be a suitable donor? Or even Volvo headlamp wipers?
I can't be the first person to have met this problem.
For the record, my Landy has done less than 50,000 miles, and less tha 200 miles since the last MOT ... in 1974.
602
Old 28th August 2014, 19:19
completenovice22 completenovice22 is offline
completenovice22 is on a distinguished road
see scotty's build in the tribute section he used small wipers for his project
Old 31st August 2014, 15:45
Hi,
Thanks for that heads up.
As far as I could make out, Scotty shortened his blades, which is something I would prefer to avoid. If there are, say, 1000 vehicles that are all eventually going to meet this problem, then an easier answer need to be found.
If there is no "off the shelf" arms that are suitable, then maybe there is a niche for somebody who is able to cut and shut stainless arms, with a high quality overlap weld. Maybe MS could be brazed, then stove enamelled black?
What overlap would be needed? 10mm? 20mm?
Volvo head lamp wiper blades are available (I'm told) in 7.5".
602
Old 1st September 2014, 20:43
Dpaz Dpaz is offline
Have you tried the series one owners club forum? My Locust has a Renault 4 wiper assembly with cut down blades. No problem they have lasted 20 years so far.
Old 3rd September 2014, 10:33
Car Builder solutions catalogue shows a range of wiper arms and blades . They are on line.
