Dino 246 Builds and Discussion Da da da da daaa daa da da, ohoho Dino |
9th September 2016, 08:08
Brilliant work,Axel... How's the car coming on?
9th September 2016, 11:50
oh yeah the car...still on hold unfortunately...
9th September 2016, 20:55
Snap...⏸
1st October 2016, 13:58
running gear
Originally Posted by Axel
Hi guys,
I really like this site and the projects you are doing here, many fantastic builds and hundreds of ideas and different ways to build your dreamcar..!
Now it's time to introduce myself and show my project:
I live in Germany in Hamburg, and I have built two kitcars already, a Countach with spaceframe and Renault Alpine A310 suspension and engine and a Renault Alpine A110 speedster based on a shortened beetle chassis.
I sold both cars 2 years ago, and played around with Porsche 996, which never made me happy, so I sold this car too.
A polish guy here in Hamburg offers GT40 kits made in Poland for a competitive price, so I decided last year to drive to Poland to have a look. I saw a frame, and some bodyparts in quite a good quality, but I did not see a finished car or a complete body. Nevertheless I bought a "rolling chassis" with body to be delivered in october, and than the story began...
Anyway, I don't wanna tell to much about what has all happened, I picked the things up in Poland in october, and brought the stuff home.
Hi Axle
I'm looking at building a 246 gt dino and was wondering what running gear/uprights / hubs have been used on your impressive build?
ian
12th October 2016, 09:18
It is a GT40 chassis build in Poland and they copied the KVA frame and uprights...
I did not do any changes to the frame and uprights, I just build a scaled Dino 206 body to fit the GT40 chassis!
I have no pics from the frame at the moment, unfortunately...
Originally Posted by thecarbuilder246
Hi Axle
ian
13th October 2016, 10:42
206
Hi
thanks axle
14th October 2016, 07:01
24th October 2016, 08:32
For those who are interested in welding, I used CuSi wire with Argon, the reason is that you work quicker and there is not so much heat transfered in the panels, the weld seam is non-corroding and has almost the strength of standard welds with wire/CO2.
But you need to practise, I am neither a welder nor a metalshaper, but I can live with the result.
One thing you realize is, welding works fine with panels who have a lot of shape- not much distorsion, but with flat panels with very little shape in them you'll get a lot of distorsion while welding them together...you need to take this into consideration when you plan your built and where to put the panels together...!
Now comes some difficult panels for the front, I am working out its face with headlights and the plexi cover for this needs a recessed surface.
I am trying to figure out how to do the recess with metal, my cutout in the frontwing is already too big, so I need to add some material...it would be so easy to do it with glass, but I want to keep the body 100% metal...
27th October 2016, 14:46
Looking really well done! I've been following on another forum as well.
28th October 2016, 06:58
I made a simple handtool to round that corner of with a hammer, works fine!
Thanks for your compliments!
Axel
28th October 2016, 13:30
Another part of the airintake, I used the same handtools to shape it. Something happened to the flat surface with the round flange but I solved it with shrinking to flatten it again.
welded in:
o/a welding the corners and the flat part
Frontend with the intake
28th October 2016, 13:37
Very well done Axel!
28th October 2016, 14:47
Axel, all very clever, i bet it all feels very solid, is it very heavy?
28th October 2016, 18:46
Axel - Great to see some more progress on your car.
...not to far off considering I did not use a wooden buck, it is all done by photos and 100% hand built..
Your accuracy is amazing and just remember that no one else will view your car through a grid.
Well, maybe just this guy.
31st October 2016, 06:38
Thanks guys, I wanted the front to be quite stiff so I have been using 1mm sheetmetal, the rest is 0.75mm... it is solid but not too heavy, I can push the car with two finger at the moment!
31st October 2016, 11:08
Impressive work Axel!
Following your build on the "other" forum as well.
31st October 2016, 16:25
Nice work
31st October 2016, 21:56
Just come across your thread tonight and have enjoyed reading about what is a fantastic build, I thought I had a major build but your build is pure magic I especially like the have a go attitude.
Are you looking at spraying the car yourself.
1st November 2016, 10:25
Thanks and yeah, I will put it under primer myself and drive it like that for a while to see if everything stays or if I have tension cracks or other issues...if everything is fine I will first spray it myself and see how it turns out, might go for a professional paintjob later...!
1st November 2016, 11:06
Another piece welded in...very complicated area but I am almost done!
Can't wait to put the headlights in...!
Hybrid Mode
