27th October 2016, 14:28
27th October 2016, 14:46
Looking really well done! I've been following on another forum as well.
28th October 2016, 06:58
I made a simple handtool to round that corner of with a hammer, works fine!
Thanks for your compliments!
Axel
28th October 2016, 13:30
Another part of the airintake, I used the same handtools to shape it. Something happened to the flat surface with the round flange but I solved it with shrinking to flatten it again.
welded in:
o/a welding the corners and the flat part
Frontend with the intake
![](http://i28.photobucket.com/albums/c236/axelkloehn/IMG_5231_zpsbnq3c4nt.jpg~original)
28th October 2016, 13:37
Very well done Axel!
28th October 2016, 14:47
Axel, all very clever, i bet it all feels very solid, is it very heavy?
28th October 2016, 18:46
Axel - Great to see some more progress on your car.
Originally Posted by Axel
...not to far off considering I did not use a wooden buck, it is all done by photos and 100% hand built..
Your accuracy is amazing and just remember that no one else will view your car through a grid.
Well, maybe just this guy.
31st October 2016, 06:38
Thanks guys, I wanted the front to be quite stiff so I have been using 1mm sheetmetal, the rest is 0.75mm... it is solid but not too heavy, I can push the car with two finger at the moment!
31st October 2016, 11:08
Impressive work Axel!
Following your build on the "other" forum as well.
31st October 2016, 16:25
Nice work
31st October 2016, 21:56
Just come across your thread tonight and have enjoyed reading about what is a fantastic build, I thought I had a major build but your build is pure magic I especially like the have a go attitude.
Are you looking at spraying the car yourself.
1st November 2016, 10:25
Thanks and yeah, I will put it under primer myself and drive it like that for a while to see if everything stays or if I have tension cracks or other issues...if everything is fine I will first spray it myself and see how it turns out, might go for a professional paintjob later...!
1st November 2016, 11:06
Another piece welded in...very complicated area but I am almost done!
Can't wait to put the headlights in...!
![](http://i28.photobucket.com/albums/c236/axelkloehn/IMG_5417b_zpsyjltafvp.jpg~original)
2nd November 2016, 09:32
Both sides welded in, sorry for the picture quality but germany is wet and dark at the moment so I cannot pull the car out of its garage...
Now comes a 5 days break, I promised family time and so there is no time for the car...
10th November 2016, 07:27
10th November 2016, 07:52
Morning Axel, not that cold in London... yet. The last shot really shows off the lovely shapes you have created. I could sit there all day, looking.
11th November 2016, 08:00
12th November 2016, 01:35
More great work Axel!
21st November 2016, 15:13
Incredible build! Great stuff.
11th December 2016, 05:00
Spend alot of time looking but rarely comment. Your build is so good it is worth breaking my silence, amazing stuff and thanks for sharing.
