Go Back   Madabout Kitcars Forum > Show off your cars > Show us your Kit Cars
Show us your Kit Cars You've just taken 2 years to build your pride and joy, right? Then why not show it off here. Let us see your creations.
Old 14th December 2009, 23:04
*Sinbad*'s Avatar
*Sinbad* *Sinbad* is offline
*Sinbad* is on a distinguished road
Default more of 'work in progress'
('Mods' feel free to move this if it's in the wrong section)
Following on from comment I made over in my other thread, here's some pic's of ongoing work on my project. You'll see I have a lot to do
New outriggers, front ones not in yet, plus one more for extra support
Home made repair panels.
New floor try out, helps to visualize things (yes it's upside down)
Fit panels, cut to suit suspension later
As you can see....lots. I started around 6 months back and time scale was 2 years, its still 2 years and will be for a while yet
Old 15th December 2009, 13:07
limpabit's Avatar
limpabit limpabit is offline
Looks like you have your work cut out there.
Keeps us updated on progress. Use this thread as a build diary.
Old 15th January 2010, 09:04
mutley's Avatar
mutley mutley is offline
mutley is on a distinguished road
Looks good well played i could do with some room like yours .
Old 3rd July 2010, 23:19
*Sinbad*'s Avatar
Default slow progress
Didn't get much work done over the winter, but I have managed to make some progress. I'm pretty close to fitting the metal subframe to help give some support to the body shell and then I can bond the new floor in place.
The visible impact of the new floor will help to boost moral too
new picture.. all the arches and bulkhead now filled in. Just cut to suit the herald suspension and gearbox.
Have Fun *Sinbad*
Old 28th November 2010, 20:08
*Sinbad*'s Avatar
Default Milestone
Well, mods to the chassis are finished and now its ready for blasting, this week hopefully.This is a small but important milestone for me.
The industrial unit where its stored has no heating, so plan now is to get it into the garage at home where i can paint it and start the rebuild.
I've rebuilt the engine,gearbox and diff, well nearly, just a couple of parts to source. The objective is to have, sometime in the spring, a rolling chassis complete with engine etc.
The body is still no where ready to try on the chassis. Changing the design of the subframe i wish to fit inside it doesn't help. But i remain confident that i can come up with a better design and make it fit. Then I can try to get the body to fit the chassis. That's the easy bit..then comes all the fiddly stuff like pedals, screen, elec's etc.
how long now? O about 2 years
Old 6th February 2011, 22:18
*Sinbad*'s Avatar
Default progress?
Hi, Just a small update, things are at least moving in the right direction. Chassis is painted and I'm bolting things back on. Not long now
The relpy when asked 'how long untill ...?' O about '' 2 years'' ask me next year it will still be '' about 2 years''
Old 9th February 2011, 18:29
JG's Avatar
JG JG is offline
Big Cheese
JG has disabled reputation
looking really good, keep up the excellent work.
Old 7th May 2011, 17:00
*Sinbad*'s Avatar
Default Small progress
Small but important progress, 99% rebuilt chassis and engine ready to go back to the warehouse where my body in stored.
I can now start on making the metal framework to sit inside the body. This will give extra strength as well as anchor points for seat belts etc. I can see this as being a rather frustrating task, mainly because I'm fitting it in whilst its upside down and with no floor in. Doing it this way allows me to make pre welded sections and insert them into place easier and keeps inside the car welding to a minimum. Overhead welding in awkward places is not my strong point. Old age and failing eye sight doesn't help either
Still have lots to do before the body gets fitted to the chassis and lots after too, but I am really enjoying the challenges..... so far.
: Yeah, its still 2 years
Old 21st October 2012, 23:51
*Sinbad*'s Avatar
Go on, hands up those who thought I'd given up.
Nope I'm still chipping away at it, I've finely got the frame work in after much shouting and cursing. I learned a valuable lesson when welding...BEWARE of distortion.
After lots of time cutting, tacking, remeasuring and then checking it all over again it fitted like a glove. Next out with the 3 main sections and sitting them on the floor I proceeded to weld all the joints. Now the fun bit assemble them on the floor and admire your handy work. ???? @%&£&... That doesn't look right!!
Arrggg, yep distortion, I should have made some sort of jig...yeah i know this now... So out with the tape measure and hacksaw the worst joints reposition and start again. Only this time with a crude jig, this involved lengths of 3 x 2, scaffold poles and lots of weight to keeps things still.
It worked, so back in the shell and lets get the floor in. I've been making a few bit as well, to replace the originals. Like the door hinge which I modified too include nuts so I can adjust the doors.
BIG moment for me, (with some help) I turned the body shell right way up and placed it on a trolly. This will help a great deal with future work on the body.
Next job is to fit the body to the chassis well line it up etc, so i can cut out the infilled arches Then the trans tunnel, do a bit more welding, then.........
Yeah yeah... I'll post again when I've made some progress.
Old 3rd October 2013, 20:48
*Sinbad*'s Avatar
Default End of era?
Oldest problem i guess with projects. Not enough spare time, well convenient time that is. Working in my garage is ok, but having to drive across town in all weathers to unlock gates/warehouse was getting to be a drag.
So its on ebay
I got side tracked last winter too, in my (warm) garage. This didn't help either.
see before and after :-
Thanks for letting me witter-away on your forum
Good luck all, Bye for now.
STEVE *Sinbad*
Old 7th October 2013, 08:33
micky1mo's Avatar
micky1mo micky1mo is offline
Originally Posted by *Sinbad* View Post
So its on ebay
So what the E-Bay item number.
Old 10th October 2013, 17:51
http://www.ebay.co.uk/itm/Project-ki...item1c375d95d5
