18th June 2009, 15:12
Tonneau
Does anyone have any pictures of the Sportster tonneau? I just received mine from Marlin and there doesn't seem to be any cut-out at the back to take into account the roll bar. I could just be being a bit thick but there are no instructions for fitting which doesn't help.
Also the centre zip is fitted at an angle so that it starts at the centre at the back and then angles towards the drivers side. By the time it reaches the front the panel is only about 12 inches wide. (I will post a picture later) I am sure there is a reason for this but I can't think what at the moment.
On the plus side it looks well made and is supplied with good fixings (lift-the-dot rather than the cheaper press stud things you sometimes get)
18th June 2009, 15:25
Just a thought, if the vehicle needs to go through IVA the lift-the-dot fasteners will be a big fail point!
19th June 2009, 07:47
Thanks Peter
The Marlin Tonneau looks like the one on the red car. It's in three parts with the centre zip offset towards the driver at the front. (Mine doesn't have the headrest pods) I spoke to Terry and she confirmed it should have cutouts for the roll bar. Marlin have the covers made by a 3rd party so it's not really their fault other than perhaps they should have checked it before it was sent out.
Apparently Marlin are now away for two weeks so they have given me the name of a contact at their supplier so I can try and get it sorted.
Life is never simple.....
25th June 2009, 23:02
Would be keen to hear your results - I bought one over the winter from Marlin not thinking that it needs to be warm when fitting else it will sag.
I asked about the cutout and Mark told me I need to cut the tonneau around the roll bar myself.
I haven't figured out how to put the fastenings onto the tonneau yet....
Andy
26th June 2009, 07:52
Personally I wouldn't want to make the roll bar cutouts myself. The material has to be reinforced by being doubled up and stitched - not really a DIY job. I spoke directly to the manufacturer and they said to send it back directly to them - which I have done. It will be interesting to see the results....
When I spoke to Lang & Potter (who make the Tonneau) they told me that they had the pattern for the cutouts - but their seemed to be some confusion between them and Marlin as to if they were standard.
Hmmmm.......
PS - I beleive that there is a tool that you can buy to fit the bits to the tonneaue - but it is expensive.
26th June 2009, 08:20
What are their details?
26th June 2009, 11:15
excellent thanks
1st July 2009, 21:54
Hows the tonneau going Robin?
2nd July 2009, 07:47
Still at L & P having the roll bar cut-outs made. Supposed to get it back by tomorrow but I am not holding my breath. Fortunately I haven't paid for it yet....
I will post up some pictures once it has returned.
2nd July 2009, 21:56
Actually, they were pretty fast getting me my right size hood so you may be surprised!
3rd July 2009, 08:37
A question for Peter....
When fitting the "Lift the dot" fixings on your hood did you use the special tool - or did you improvise?
3rd July 2009, 12:36
Pictures of tonneau. Hopefully will be fitted this weekend (assuming everything is in the right place)
Detail of the cutout for the roll bar. Not really a DIY job this unless you happen to have an industrial sewing machine and a supply of the material.
3rd July 2009, 18:47
What colour is your tonneau?
It would go very well with the paint scheme I have in mind (assuming I ever get that far!!)
Rgds
4th July 2009, 18:38
I tried to find someone with the tool to borrow but no luck.
I used a hollow ground hole punch for the holes (you get some pretty cheap sets off ebay) and then I sacrificed one of the fixings. If you put a block of wood behind and hit it with a small hammer the tabs will pierce the material. Use the end grain of the block of wood as its softer. Then replace with a new one and bend the tabs over with a pair of long nose pliers. A bit time consuming but quite easy once you get going. I've got some spare fixings if you need any extra.
...peter
5th July 2009, 19:15
Originally Posted by Mike
Rgds
It's actually black - pictures are a bit misleading.
5th July 2009, 19:17
...peter
Great idea! Fitting has come to a halt at the moment though. I don't know why - but the cut outs for the roll bar are - err - in the wrong place. Hmm....
5th July 2009, 21:28
How frustrating!
6th August 2009, 20:03
After a number of delays (long story) I now have a tonneau that I can fit.
Can anyone tell me which way up the base of the lift-the-dot fastner goes? (I mean the fastener that fits to the material - not the stud) It is slightly concave and has four little pressed out areas. I assumed that the pressed out bits are positioned towards the material thus offering more grip. But now I have fitted a couple I am not so sure. Does anyone know?
6th August 2009, 21:37
Hi Robin, glad you got your new tonneau. I think I fiitted mine the other way round with the concave side towards the material. No idea which is correct as i've never seen any instructions for these. It just seemed neater that way to me.
...peter
