Old 24th June 2008, 20:06
chrisrsmorriss chrisrsmorriss is offline
Kit Car Dreamer
chrisrsmorriss is on a distinguished road
Question Door mirrors.
I find that the door mirrors could do with being a bit higher up. The ones on Rich's old Vortex are positioned quite low and the rear wheel hump obscures much of the view. Any advice on what mirrors with a cranked arm (to raise the height) might fit? A BMW M3 type one might do the job, and they stick out a bit more which would help, but it does need to have convex rather than flat glass.
Thanks,
Chris Morriss.
Old 26th June 2008, 17:19
ricola ricola is offline
ricola is on a distinguished road
I quite liked the look of Ken's modified Rover 75 wing mirrors...
Old 26th June 2008, 19:22
Kit Car Dreamer
Thanks Rich. So that's what the mirrors on Ken's car are from! If you're around Ken, can you let me know what mods you had to do to fit them?
Thanks,
Chris Morriss.
Old 27th June 2008, 10:00
Ken did explain to me how he did it
if you compare this pic with a standard mirror, he made up an aluminium disc to fit in the door recess, then cut down the rover stalk and bolted it to the new base. The base replicates the stock two bolt fixing of the rover 100 mirror base. Bit of filler to smooth things off and a lick of paint and it's done!
When I looked, Rover 75 mirrors were quite pricey which put me off, Rover 25 are very similar if not the same so worth investigating too. FYI: the standard ones you have use heated rover 75 'glass' already, they also sit higher than other phantoms, most have problems with clearance between the mirror and the door...
