Old 25th February 2008, 23:39
grant620 grant620 is offline
grant620 is on a distinguished road
Default Rover K16 / T16 Solid lifters
Hi
Got a set of T16 Solid lifters here which have been used, but are mint (no internal moving parts!)
These are Piper and cost £358 + VAT per set new with a single set of shims.
Looking for £260 with a new set of shims that need grinding to specs (can send them later when you decide what thickness you need, but 5mm is normal) AND a set of shims that may be of use to you (already been ground, but may be able to use some)
Can be used with standard spring caps.
OR
I've also got a used set of Cromo Spring caps designed to hold the shims. This makes set up and assembly easier...
These are £54+vat retail
£45 all in if bought with lifters
Or offers of course
