Old 1st November 2007, 12:07
alackofspeed's Avatar
Default F.A.O - Ric H - Type R SVA weights
Rich,
I'm in the midst of applying for my SVA test. Could you be so kind as to let me know what weights you quoted on your SVA application form.
Thanks,
John.
Old 1st November 2007, 17:15
SDMC001's Avatar
SDMC001 SDMC001 is offline
I have on my SVA certificate 450 KG front, 500 rear, gross weight 900KG.
Steve
craig's Avatar
craig craig is offline
I'm sure Rich had something like 400/600 as I remember us taliking about it at lladlow being a tonne, sure he will clarify
Also think he said when weighed his car was 720kg if my memory serves me correct
Old 1st November 2007, 20:08
Cheers for the input chaps.
Steve - It'll be interesting to see what Rich's value are, and how they compare to your k-series car.
Old 1st November 2007, 21:46
Ric H Ric H is offline
Hiya,
On advice from Marlin I quoted axle 1 500kg, axle 2 550kg, MGVW 1050kg.
Seemed to work!
Actual axle weights measured at SVA were iirc 320 front, 420 rear (full-ish tank of fuel, but not including me...)
Good luck!
Old 1st November 2007, 22:04
Cheers!
Old 2nd November 2007, 19:50
DavidH DavidH is offline
OK stupid question and I'm sure this is just me being thick but how does this compare to the 550kg quoted by Marlin http://www.marlinsportscars.co.uk/5e...ld_engine.html for a k-series build or is it like the estimated budget and build time e.g. on the very optomistic side.
Old 3rd November 2007, 10:04
Take Marlin's figures for most things with a pinch of salt!
Remember the actual measured weight of the car can be considerably less than the quoted axle design weights and maximum gross weight (which are used by the brake system calculations at SVA to govern acceptable brake effort).
I ended up with an unladen weight on the SVA scales (we'll assume Marlin are quoting without fluids or fuel!) of about 720kg for the Type-R car. I reckon if I was a complete weight nazi during the build, and didn't fit various options (additional panelling etc) I could probably have got the Type-R car down to about 680kg, which probably means the smaller K-series builds could achieve about 630kg, realistically.
Rich (Bigrich) has built a pretty stripped-out K-series version. What was your measured weight at SVA Rich?
Richard
Old 3rd November 2007, 15:15
Jon@JNRacing.co.uk's Avatar
Jon@JNRacing.co.uk Jon@JNRacing.co.uk is offline
Jon@JNRacing.co.uk is on a distinguished road
Mine is 482KG without body pannels or aero fitted with a 42/58 split at the moment will be 45/55 when finished though and set up.
Old 4th November 2007, 15:59
SDMC001's Avatar
David
Mine at SVA on the scles was about 820 K as with me in it and a full tank 5 gals. The figure arounf the 700 ish mark must be some where near right if thats the case.
Steve
Old 6th November 2007, 09:02
Just for the records, my T16 Turbo was 720 kg.
Which is good news...the Honda boys are almost identical weight to the T16 turbo boys...
Old 6th November 2007, 19:58
Doesnt sound like theres too much of a weight penalty for using the Turbo or the Type-R engines over the K-series, interesting. Certainly means I need to try and make mine as lean a build a possible.
