Old 13th August 2007, 21:41
alackofspeed's Avatar
Default Rear lights
A very quick question:
What light unit (if any) are people using in the lowest of the three outer ligth apertures? I've bought some lights, which are fine for the upper two apertures, but I'm struggling to find a smoked reverse and fog to go in the lower aperture.
Any help would be very much appreciated.
Thanks,
John.
Old 13th August 2007, 23:05
craig's Avatar
craig craig is offline
Can you not make the hella ones you have fit? they are smoked or mine are anyway think you bought the same?
Old 14th August 2007, 06:12
limpabit's Avatar
limpabit limpabit is offline
Hi guys.
I got the Hella ones for the top two with the reverser and fog in the middle two.
The holes for the lower two seem verry small. The only ones I can think that may fit and the classic looking ones for the older looking cars.
Old 14th August 2007, 12:24
They can be made to fit, but I don't think it'll be very elegant. The 55mm lights with the rings are perfect for the upper two, and look damn smart, but I'm not convinced the lowest will look very good with the hella 55mm unit in it.
p.s. John - your PM box is full.
Old 14th August 2007, 16:59
limpabit's Avatar
Cheers John for the heads up re PM box full. Had a good clear out.
Old 15th August 2007, 09:26
craig's Avatar
Oh yeah your right! not bothered with mine as not done anything since clutch will start again in oct hopefully......
It would cost you a little more (only about £40) but something I might be doing is using the bottom recesses for reflector and bying the hella ring which is tail and brake light in one thus leaving 2 centres for fog/reverse lights
Craig
Old 15th August 2007, 19:33
Ric H Ric H is offline
I thought the lowest were for reflectors, and were an SVA requirement? Or do the rear lights reflect sufficiently?
I got some reflectors anyway!
Richard
