Has anyone built themselves a GRP hardtop?
As title.... I intend to build a GRP hardtop for a roadster, with the shape similar to a soft top. Intention being to use it in the Winter. Wanting to keep the weight as low as possible, and a good enough finish to paint (probably matt black paint).
"a roadster"... as in, a z3? If so, should be able to buy all the clips and fixings for the hard top which they made for the car. Shouldnt be too hard to make a thin metal frame which connects all the bits, and then cardboard, parcel tape and grp to connect them. Same with an MX5, and with the price of those hard tops, I wouldnt be surprised if someone has done that a few times already.
I wondered if something like the lightyear fastback top might be a good starting point, if you can find one (or something like it) on this side of the world (light-year are aussie-based). https://www.miataturbo.net/build-thr...-48089/page28/ |
Oops... sorry for causing confusion. It's a Calvy Mitchel (hence my user name). - old style roadster. Nearest equivalent is an NG kit car.
I've seen it done using a timber frame and 1/4" plywood clad with black vinyl. You could glass over the wood and then paint it, depends on what finish you want.
Thanks for your comments lucky. With your experience of GRP, do you consider a horizontal flat panel of the roof with a total of 1200 gsm chopped strand mat would sag over time? If so, maybe adding 5mm nidaplast honeycomb reinforcement and 450 mm layer under may stop it sagging? roughly 1m x 0.8m panel? I'll be grateful for your opinion.
I'm no GRP expert, best to talk to a laminator for their opinion.
The Tribute guys could probably take a splash mould of the existing hood and then lay up a basic shape for you. Reinforce it with f/g rope as required.
Try asking Chris or Dan at Tribute or Gary at Formosa. There's a lot of info on youtube too. There aren't any big secrets , sounds like you are pretty familiar with the stuff having built a caravan ! A small hard top should be quite straight forward.
You could always try a conventional Carson top style, using electrical conduit and chicken wire but…
A grp version of a Carson top is covered in detail here: https://www.jalopyjournal.com/forum/...on-top.240611/ I’ve had the thought of using the existing hood, wrapped in cling film and tinfoil, to create an original mold. Then make a more structured part from that. Please post if you do move forward with this! |
Thanks for that. I planned to use foam board, but now have a fiendish plan to save effort (because I'm lazy). I'll report back with my result (should be by Summer)
I once saw a JC Midge with a hard top that looked just like a soft top. It was only when the owner tapped on it that you knew it was fibreglass and not canvas. Good luck.
Have you managed to make any progress so far ?
Pots of resin etc arriving tomorrow - I'll start when the weather gets warmer.
did you go for it ?
I've not had time yet = too busy restoring a mates 60 year old caravan
