274 in restoring
1 Attachment(s)
Hi Champs,
a long way to temperero. Carbody is now lifted up. Now will come the drivetrain and suspension out and the frame will go to sandblasting to prepare a proper welding work and outrider repair in the best quality what we can get. Greetings Rene |
Are you making any changes Rene.
No, full restoration. The concept was right and in nothing wrong.
Simple,fast,without endless modifications and nitty critties. The issue was low part quality of the spender frame. May engine and gear. Have to check. Regards Rene |
In generell view, based at a donorcar should be the frame,suspension,engine,gear overholed and restored.
Or work with exchangeunits. Ok, that's more expensive. But at the end, if you change and modify more times? |
