Parts for any new Ribble / Sammio builders
As i come to the end of my build i find myself with a ruck of new and used parts including but not limited to:
Trunnion Rebuild Kits New 4 speed gearbox used. Couple of wishbones and rear uprights used plastic gearbox cover new but has a hole cut in it loads of brand new bearing bushes etc boxes of used but perfectly serviceable imperial nuts and bolts 4 brand new 185/70 R14 tyres which were fitted and then removed in favour of something a little skinnier A brand new pair of seat runners. Various pipes brake tubing unions etc. At least one driveshaft A prop shaft Used but good waterpump A Weber DCOE 40 in bits At least one used from upright assembly. I really cant be arsed to go through it all and sell a bit here and bit there for £5 so was wondering if anyone want to come over with an estate car or van and take the lot? Price is negotiable but will probably be less than i could weigh it all in for. I need the space more than i need to profit from the sale of the bits as my next project is sitting in the wings. |
just realised there's a fuel tank as well
Might be interested in the Weber DCOE in bits if I could tempt you to sell that separately?
hmm make me an offer. Its a complete carb but totally stripped.
What series is it? Looking for an 18.
What gearbox is it, and where are you?
Cheers |
Craig,
Your in luck https://lh3.googleusercontent.com/-h.../IMG_02265.jpg you can see why i stripped it, the previous owner painted in a nice lurid green PM me your best offer mate. Mac |
Marc,
Pic of the gearboxhttps://lh3.googleusercontent.com/-p.../IMG_02266.jpg Im in TernHill Shropshire Mac |
Thanks Mac - do you know if it is 3 or 4 syncro - I have a Mk3, which is only 3, but I understand the Mk4 was 4 syncro.
Thanks |
Marc I don't honestly know, its what came with the "donor in boxes" I bought which is a MKIII 1300 with an FD prefix engine. Unfortunately I cant find out how to tell the difference even after 30 minutes on google!
actually just read somewhere that the 3 synchro has a square output flange and the 4 synchro has a round one. If that's the case theen its a 3 synchro.
Ed so what is the difference in prefix between the 2?
Without doing a lot of research I don't know but here is a link the Rimmers Spitfire gearbox pages...
http://www.rimmerbros.co.uk/ItemList...3-Rail--m-3167 Ben Caswell is your man, he would know off the top of his head, I am sure. I have what I believe is a freshly factory reconditioned Dolomite 1800 single rail with a J Type o/d and the two letters nailed the exact box. I don't want to part with the Dolomite box right now because I might need it, it fit's my 1275 'A' series BMC engine. I think the two letters are stamped on the top next to the lid, from memory but your box may be different. |
PM sent
Weber DCOE has gone to a new home.
Only way to be sure its a four synchro is take the top off and have a look. If it is a MkIV box the prefix is FH the number is on the top edge of the main case.
Well there you go! Cheers Ben.
Gearbox's are a black art to me that's why I have a a "gearbox man" what am i looking for when and if i pop the top off?
You should see the difference in the Rimmer link I posted above. |
