Tribute Mx250 build progress.
Hello,
My name is Billy and this is my first time running a thread so go steady on me! I will be posting my build step by step inc photo's over the next month. I have a 3/4 day slot booked at my freinds paint booth at the end of the month so it has to be ready for then. Cheers Billy |
Looks like you're trailblazing! good luck matey and lets see loads of photos :)
Hi Dave,
I am starting a new post in the new tribute section tonight. Cheers dude |
The donor, mk1 R reg 1.6 16v one owner. The tribute roll bar fitted! (with ease) I know i should of sprayed it before fitting but i was eager to get started and quite like the grey primer colour ha.http://i1162.photobucket.com/albums/...n/DSC01657.jpg
the rear trimmed and ready to go!http://i1162.photobucket.com/albums/...n/DSC01654.jpg
Roll bar fitted and both kit mounting panels. http://i1162.photobucket.com/albums/...n/DSC01663.jpg
the rear dry fitted, i thought i was going mad as could not get it to sits level, then noticed a knackard spring! hence sitting low at one side! new springs enroute!http://i1162.photobucket.com/albums/...n/DSC01665.jpg
dry fit front end, hardly any trimming needed, hugs the car well.http://i1162.photobucket.com/albums/...n/DSC01661.jpg
I filled the arches with expanding foam, it has made it very solid.http://i1162.photobucket.com/albums/...n/DSC01672.jpg
The roof married up perfect. NOTE, filled with epoxy R-KEM (rawl fixings) sets rock solid to avoid cracking.http://i1162.photobucket.com/albums/...n/DSC01673.jpg
I have used the MX5 head lights, fitted the fixing ring to the inside of the shell (fixed 6mm threaded rod with the k-rem fixing resin then fitted the head light frame so that they can be adjusted by moving the nuts. The light frame sits proud of the body and i think it looks grand, I also cut the side light fixing out of the mx5 side lights and carefully drilled a hole inthe head light bowl and bonded on the side light fixing. So now i have the side lights in the head lights and another plus is that all original wiring (plugs/fittings) and makes life easier. (pics of side lights to come) http://i1162.photobucket.com/albums/...n/DSC01692.jpg
http://i1162.photobucket.com/albums/...n/DSC01690.jpg alittle sanding to do but other than that...job done.
Holes in the bonnet for the wipers. I cut some wiper legs from a scrap car and slid alloy tube over them and held in place with rol pins (so can be removed without to much hassle)http://i1162.photobucket.com/albums/...n/DSC01674.jpg
Photo of back of the head light, I cut the plastic side light fixing from the side light/indicator lense and bonded it to the rear of the head light. Make sure to totally seal the joint otherwise the lamp will mist up. this saves having to have a ugly side light elsewhere that in my opinion would spoil the lines of the car & its using OEM fittings and saves cutting wires etc and best of all its FREE.http://i1162.photobucket.com/albums/...n/DSC01694.jpg
