Wanted: Gear Linkage assembly and Rear Hub Assemblys
Hi,
First post here...i've just started my 5exi...the donor was a 420 gsi turbo but i believe i will be short of a couple of items that i need from a later 216 "bubble" shape car. Can anyone point me to a link/website/scrap yard etc where I should go to get these itesm? Other than that...I am about to start "rivnutting" the floors on! Cheers, John marlinturbo |
Firstly welcome to the 'club'. Where are you living? There are a couple of national companies that will be more than able to relieve you of a little cash, but normally your local breakers are helpful and cheaper. As for the gear linkage. I used a 400/45 donor. The linkage rod was too long. I cut the weld at the gear stick end, then cut it down and re-welded it. You might be able to do the same/ similar. Your right the rear hubs are only on the 200/25 car. You might need a radiator too? |
Hi,
I'm in Taunton...so not thaaaaaat far away from you :-) I'm going to Marlin sat morning to hopefully collect the steering rack. yes i will need a rad as well... i'll try my local "boys" first for the parts.... The one issue I have is the gear linkage assembly...There is obviously a linkage mechanism in the kit to attach the cables to the 216 style box for RWD application...Will this kit fit the PG1 g'box as well? Mark is adamant that I have to get the 216 style linkage... john. |
There are 2 companies that advertise in Kit Car. Rover Spares and Viking Spares. Don't know the numbers.
You could try http://www.universal-salvage.co.uk They have a branch in Westbury. Or: http://www.silverlakeautoparts.co.uk/ Bit further, but they do have a lot go through, they seem pretty cheap and they deliver. |
hi john
I am also in process of 220 turbo. I live in weymouth but i am often in taunton as my mother lives at shoreditch all the best tony gigg |
The orange Marlin has a 1.8l engine in it. The PG1 gearbox is normally fitted to the 1.8l and 2lt engines irrespective of car. |
sorted...i called twigworth breakers...they had the bits...and a mate has collected them for me!
right back into the garage for even more rivetting :biggrin: john. |
