Morning rain stopped play , Geoff .
Jag the pictures are there for me , can anybody else see them? Geoff .
Thank you for the updates , Geoff .
Good evening , the dash and the way that i put the instruments together is a mission , but it really is a good finishing touch , pretty much the only clue to the Z3 heritage is the small BMW marked on the bottom corner of the windscreen , although at one point during the morning i did see and hear somebody say it was based on a Z3 after googling a registration website! Geoff .
Good evening all , my car lives outside but is usually covered with a "Triple lined car cover" this works fine until it is really windy as in the last couple of days!
so the first snow of the winter has fallen , i wonder if Jeff used an anti-snow protection coat when he had finished spraying my car . In my opinion the paintwork looks just as good as when i picked the car up , so thanks Jeff , Geoff .
Evening Jag thanks for that , this is what my dash looks like.
The top row of switches are from left to right,a standard Z3 air con switch modified to look "old fashioned" then two switches for front and rear fogs (only rear in use) then a switch for the Hazards.
The next row down are the three Z3 Heater controls again modified. The hole above the line of four switches allows me to see the Z3 mileometer (this is where i positioned the Z3 instrument cluster PCB) this came in useful at MOT time!
The two things left to do are to make a panel to replace the Z3 Glove Box which no longer fits and to find some 8mm sticky vinyl letters to stick on the heads of the various switches
F for Fog L for Lights etc , Geoff .
Good afternoon , ref the glovebox , it would fit in relation to the dash , but because of the curved edge on the right hand side of the glovebox i could not work out a way of combining it with a new centre console , i definitely did not want to retain the standard Z3 centre console as that would have been the last thing in my car which would give a clue to its origin . When i had my MOT done (last month) the tester did ask the mileage reading as he could not see it , i pointed it out to him and he took the reading , i dont know what would have been the result if he could not see a reading (fail? or advisory?) Geoff .
Good afternoon last week i spent a couple of days down in MK , i had not been for a decent drive in the SWB for a couple of months so i used that , first the bad points ,
1 The blast of air that came into the interior that was so refreshing when in Italy 2 years ago was bloody cold when its just come from Siberia!
2 Metal gear knobs can get very cold when the outside temp is freezing .
good points
1 I drove back on Friday (just gone) when there was a couple of inches of snow on the ground and my narrow tyres worked really well as everybody else was sliding around on their wide tyres .
2 The heater works really well .
Just need to wash it know , Geoff .
Will check and post up first thing tomorrow , Geoff .
Good morning , my wheels are BMW 5 series 6.5 x 15 ET20 steels with Avon ZV7 tyres 195/65/15 , i bought the wheels from Mister Towed and it was he that drilled all the small holes (god knows how much time and drill bits) , i have had them blasted and coated , no issues on full lock , thanks Geoff .
The following Ebay purchase is certainly not the most interesting item i have bought! but they do the job ,
https://www.ebay.co.uk/itm/20-x-alloy-wheel-bolts-nuts-lugs-in-Black-M12-x-1-5-17mm-Hex-taper-for-BMW/281790278875?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 ,
I have also changed the centre console to a MK2 version the MK1 hid the 3 BMW heater controls but i could not get them to operate efficiently i did want to hide them as they are the last item in the interior that gives a clue to the BMW heritage .
The final interior change is a net fitted behind the seats to give extra luggage capacity .
[QUOTE=couerdelion;94524]What does the AFFH stand for?
Its Air Con/Front Fog/Rear Fog/Hazards , Geoff .
Couerdelion my light switch is fitted to the right of the steering column in the dash in a similar position to the Z3 , i have a horn button fitted on the left hand side of the steering column (this can be seen in the picture showing my centre console) Geoff .
On Friday last i decided it was time to have the Air-Con re-gassed , for various reasons it had not been used for some time , after ringing around it became clear that the days of the £40 recharge are long gone , i ended up paying £80 plus a couple of quid extra for a failed seal . Now dependent on which internet site you believe the cost has increased because
1 A new different more expensive refrigerant has to be used,
2 Imports of the cheap stuff from China have been banned,
3 The older charge units that some garages have are no longer suitable ,
anyway its done just in time for this years UK heatwave , Geoff .
Good morning i am sure that some on here will be aware that my SWB is for sale , a constant question i had was what was my car registered on the V5 know it never bothered me that my car was still on the V5 as a BMW Z3 , but i decided that it would probably be worthwhile to have a change , in fact one person strongly suggested that it would no longer be possible to MOT my car as it did not look like a Z3! , i MOTd it a week later with no problems before sending the paperwork of to the DVLA ,so i am know driving around in a Tribute 250 , Geoff .
Good afternoon yes that number is on retention and has been replaced with
A2 HPU , Geoff .
Morning , i am guessing there will be no work outside today! Geoff .
I need to update the statement about not working outside , once the snow was cleared off the cover and the cover put on the fence to dry , then clearing the drive and putting some grit down , the sun was actually good to work in , although what was i thinking when i bought a house without a garage , Geoff .
