Seanicks Unnecessary Life Complication
By seanick · 183 updates · Oct 2012 to Sep 2019
March 2013
4 Mar 2013, 1:50am Chassis and Body
It a bit of a grey area...
Three coats on. Its now 01:50, and time for bed.
This primer is nearly the finished colour.
And this is why you need extraction for the 'paint booths
....its all a bit hazy..
4 Mar 2013, 5:18pm Chassis and Body Interior & Trim
Hi Gary, its a 'normal' 1 litre spray gun. It was a bit cold so the pressure was quite high as I had thinned it a fair bit, but wanted it on thick as poss, as its Hi-build primer! Saying that it was warm enough in the tent for it to inflate with the warm air and need to be clamped down!! 4kw of heaters maintained about 15 deg, when it was about 4 outside.
4 Mar 2013, 5:36pm Chassis and Body
Out the shed this morning. Its now back home and under wraps for a few months untill I have time, space and enthusiasm to finish it.
[IMG][/IMG]:eusa_dance: [IMG][/IMG]
:peep:
[IMG][/IMG]:peace:
:icon_cool:
:madgrin:
Shut line on the lower bonnet is a bit shit here, please ignore that for now!!
5 Mar 2013, 10:30pm Engine Mechanical Overhaul Chassis and Body Electrics Interior & Trim
Thanks all! Would love to carry on apace but Everything has backed up, business workload, paper work, house, garden, boat and most importantly...family!
Now its back home I can dry fit the lights etc, and finish the interior in the odd moment. We have a 1904 yacht in the shed now, and has to be out by Easter (see Mikado) on my website.)
Whilst I do want to finish it its the process of making things that I enjoy, so to throw it together at this stage would be nuts, and really annoy me! There is still more fairing to do on the bonnet, the rear wing joins are a bit Sharpe and radius ing where they run into the body. I also have to make the rear exhaust, change the door handles, make thewheel center trims and fit the spinners. Chrome window surrounds,vent trims, chrome the wipers close of the inner boot from the rear valance. Front inner wheel arches need to be made, plus the whole of the underside and all arches need schlutz-ing. Needs some trim panels to duct the air from the grill to the radiator, whilst still allowing the bonnet to open, plus cold air ducting to the air filter. Wiring needs extending to the flip front lights, plus screen squirter's. Some poly bushes are needed on the rear as some old ones are not quite right. After that a four wheel alignment. Finally some Dinitrol in the box sections to prevent decay in the future.
Finally it needs flatting back, more hi-build primer, then flatting back again, before I have a go at top coating it.
So when I have done that, I will be nearly there!
It took me seven years to rebuild my boat, so a couple of months more on this one is no problem!
Thanks again for all your kind comments and encouragement!
cheers,
Nick
5 Mar 2013, 10:57pm General Update
I'll have it done by then!!!!
It only March and April I need to back off!:lalala:
15 Mar 2013, 4:54pm Chassis and Body
Hi Peeps,
Untill I flat back its hard to say, but the primer does makle you see lots of bits you have missed, and I mean real howlers! When its all colours its hard to see whats what after a while, but then primer gives you an idea of how far you have got. It fills in scratches and pin holes, but anything larger shows up more clearly so you can get it next time. I recommend a coat of primer just to regain ones sanity!!!:dizzy:
How is yrs coming along?
20 Mar 2013, 10:00pm Getting Underway Chassis and Body
There goes my last bit of two pack primer!
poor car!
22 Mar 2013, 8:42pm General Update
Now this is walking the plank! (and its quite a long way down!)
April 2013
15 Apr 2013, 6:35pm Mechanical Overhaul Chassis and Body
Hi Hammy, finally pulled up the covers. Tyre to arch clearance is 40mm, although 50 mm on the center. Hope that's enough!
Big Rich, re stonleigh, um, not sure, if yes then it will be in primer!
REALLY busy work wise, held up by the cold weather, so working eves and six days a week :-)
Mind you, bit of room in the shed now this one is in
17 Apr 2013, 4:04pm Chassis and Body
Ply and foam backed black stuff over the top. I think I have done this already. no visible GRP anywhere inside.
17 Apr 2013, 5:24pm General Update
It can be, and its what any sane person would do. However, I didn't because............
I wanted an air gap for insulation. Cool in summer, warm in winter.
I wanted to run the wires for interior lights and heated rear window under it.
It avoids possible wrinkles and compound curves on the lining.
Would I do it again? No, I would just stick the lining on !!
I also had to lower the roll bar a bit to make it fit!!
June 2013
23 Jun 2013, 9:39pm Electrics
Well I got one headlight cut out and sort of fitted this eve. Also marked out fir my rear lights and ordered the rear reflectors and number plate lights. Its nice to be back on it.
MOT penciled in for Thurs:rofl:
24 Jun 2013, 10:25pm Electrics
MOT now sat at 8am. Fitted the other headlight this eve, temporary numberplate's then removed the back box and welded in an extra bend to drop the tail pipe down. Final fit to.arrow. I looks better with the lights in place!
28 Jun 2013, 9:08am General Update
Nice Arse!
[/IMG]
Now, where shall I put that fugly fog light??
28 Jun 2013, 9:37pm Chassis and Body
Well it is inside the boot, but it sort of pops up when you need it.
Just refitting the door seals. Rear window in, all the lights work. Had a quick whizz around with the vacuum, and just sort of throwing some interior bits in. Still need to fit mirrors.
MOT tomorrow am, then hopefully over to Poole to see which bits fall off along the way......
30 Jun 2013, 9:05pm Engine Mechanical Overhaul Electrics
Same post as on BBQ thread but.....
Thanks for a great do Chris! Thanks for coming to find me too, I promise to get a sat nav that works or a map that has Hurst Moreton on it for next time! Better late than never!
The new workshop is fantastic and perfectly retro for all your cars. Nice size workshop and a forecourt too. A good show of 250's, and nice to put faces to forum names and look at the cars. It interesting how they come from the same moulds, but all look so individual.
It was a long day for me, last minute jobs in the morning, insured it (£115, Adrian Flux) then off to the MOT at 10.30 (already late....). Arrived with smoke pouring out of one front wheel, and a seized caliper. Super MOT tester Mark had it on the ramp and a new caliper arrived before I new he had ordered it!! A tweet of headlight aim, some brake bleeding and it passed. :-D Many thanks to Mark for his enthusiasm and time on a Saturday
Hoofed it 95 miles down to Dorset, where I clocked up another 25 miles getting lost as my phone is ill, and confused.
After the meet I hoofed it again (all legal limits Towed!) to Washington just past Arundle bringing the day's total mileage to 180. :-/
It was my first real drive in an MX5. It loves to rev, and goes around any corner I thought I would not make....great B roads in Dorset. The exhaust is a bit of a drone on the m way but worth it for the rest of the time.
Back home today so total miles about 225 this weekend.
THANKS AGAIN TO CHRIS AND DAN FOR A GREAT DO!!
30 Jun 2013, 10:25pm General Update
Yeeeeeeeeee har!:shocked:
(it felt faster than it looks!)
July 2013
2 Jul 2013, 8:00am General Update
Well, after a friend of a friend was arrested last week for boasting how fast he had taken his BMW up to and posting it on Facebook, I wouldI be silly to do the same, wouldn't I?
October 2013
20 Oct 2013, 9:54pm General Update
So practical for camping :dance:
