11 Mar 2021, 6:29pm
Interior & Trim
March 2021
11 Mar 2021, 6:34pm
General Update
Heres the standard mx5 clocks removed, with the perspex cover off
11 Mar 2021, 6:35pm
General Update
Facia fitted
11 Mar 2021, 6:42pm
Mechanical Overhaul
Now this is where I luck out completely! I managed to source some glass guage faces from some old redundant equipment that's been scrapped nearby after an hour or so of hunting, I managed to find 2 x glass/stainless 95mm faces from some old pressure guages, I butchered some smaller pneumatic guages to get me some 45mm perspex faces with stainless surrounds, once cleaned up, I have created this!
11 Mar 2021, 6:43pm
General Update
11 Mar 2021, 6:48pm
General Update
Cleaned it up, put some slithers of red vinyl on the needles, fit some leds in place of the old green filament bulbs..... refit in car.... turn a few led bulbs round...... realise the rev meter is not reading zero.... take apart...[ repeat everything... refit..... test.... take picture..... post
11 Mar 2021, 6:49pm
General Update
13 Mar 2021, 8:01am
Chassis and Body
Thanks! Been a soggy few days, so haven't made much progress, the paintwork is almost up to scratch (excuse the pun) I fitted some led bulbs in the interior/footwell lights, managed to squeeze in 6x led 38mm bulbs by manipulating the terminals a little bit, also repaired a crack in the dash cowel and ordered a tan stitched leather wrap to cover it.
I like the idea of interior lights to replace the sunvisors, would make a huge difference at night as the footwell lights are only good for doing up your shoe laces
13 Mar 2021, 8:08am
General Update
13 Mar 2021, 8:16am
Chassis and Body
Electrics
Probably will order a pair of these, if I'm having a nice interior, I'd like to be able to see it!
I also fitted some RDX mini led indicator lamps (E marked) as apparently using led bulbs in non led units is now an MOT fail, they are very bright, already I had load resistors fitted, so was only a 10min job, only 2 screws and no messing about with the chrome ring /rubber seal on the old lucas units, will post a pic later...
Todays jobs are to refit the rear lights, I'm going to try some matte black vinyl over the rear centre panel/number plate area, can easily be removed if I don't like it,
13 Mar 2021, 8:19am
General Update
13 Mar 2021, 12:20pm
General Update
Heres what it would look like
13 Mar 2021, 12:24pm
Chassis and Body
Covered the paint in wax to prevent the vinyl from gripping as i didn't want to pull any paint off..... Just been cutting it to size to get the shape I want, then ill draw it on inkdcape and run it through the plotter,
13 Mar 2021, 1:58pm
General Update
14 Mar 2021, 10:04am
General Update
14 Mar 2021, 10:11am
Electrics
Settled on this arrangement, now I can get all the lighting working again....
14 Mar 2021, 12:42pm
General Update
14 Mar 2021, 12:44pm
General Update
Lights are back in and connected up, numberplate send led lamp also fitted.
14 Mar 2021, 6:50pm
General Update
14 Mar 2021, 6:54pm
General Update
Moody night photo!
