Ericholm 250 SWB Build thread
By ericholm · 243 updates · Jul 2015 to Nov 2021
September 2015
11 Sep 2015, 1:51pm General Update
Nope, not yet as not fitted them, just lodged them up for photos, will do it when I get around to doing that job, shouldn't be too long now.
Cheers.
12 Sep 2015, 8:56am Chassis and Body
Thanks WCA and IanA for the bonnet stay suggestions, looks like we have to be creative, The bonnet section will only get heavier as I add fog lights and 'other' elements.
:tea:
12 Sep 2015, 11:45am Mechanical Overhaul Chassis and Body Electrics
5mm front wheel spacers arrived and fitted today, perfect clearance now on front wheels at full lock
All wiring crimped with spade terminals, allow easy removal for spraying.
Coilovers fitted on all for corners and adjustments made
Next job, remove drivers side hoop and cap off, then I will start on the doors for real.......nervous :eusa_pray::shock::twitch::noidea::eusa_eh: :eusa_think:
12 Sep 2015, 6:24pm General Update
If it works, I only need 1 :eyebrows:
13 Sep 2015, 9:21pm Mechanical Overhaul
Hi, on mine its 40mm, I have coilovers and they are pretty much on the lowest setting.
:faint:
Cheers.
19 Sep 2015, 9:50pm Chassis and Body
Rear end refit today, to get things aligned and in place for paint.
Also had a go at getting door mechanism working on passenger side.
DSCN4748 by eric holm, on Flickr
DSCN4751 by eric holm, on Flickr
DSCN4754 by eric holm, on Flickr
DSCN4756 by eric holm, on Flickr
DSCN4759 by eric holm, on Flickr
DSCN4760 by eric holm, on Flickr
DSCN4761 by eric holm, on Flickr
DSCN4762 by eric holm, on Flickr
DSCN4764 by eric holm, on Flickr
DSCN4766 by eric holm, on Flickr
20 Sep 2015, 5:52am Engine Chassis and Body Interior & Trim
Paul L - for the door mods i am using a standard mini handle and it has a bullet type piece of plastic that pokes out when the handle button is pressed. This hits the 41mm x 35mm 'strike' plate that you see I have bolted on to the door working on the pictures in my previous post.
As you can see I had to open up the hole a little bigger to be able to get access to secure the strike plate, I did all this from the outside of the door without taking any of the interior trim off.
So the strike plate pushes inwards and opens the door.
The mini handle is attached to the new door skin that covers the outer part of the door and just bolts on like a veneer piece.
No idea about other door handles, as only using Mini ones, sorry.
I hope this all makes sense.
It's gonna be a nice day again today so will continue efforts, my todo list on this build in much smaller now and fits on one page in my note book. Yay!
20 Sep 2015, 6:56am Chassis and Body
Hi, yes that's a good point, however, I expect the door skin to be removed for prepping and painting, especially as the surface of the skin can be seen through the bottom of the window right, so this would be impossible to finish and spray in position?
20 Sep 2015, 7:03pm Chassis and Body
Boot switch and Power/usb/cig lighted socket in boot
DSCN4768 by eric holm, on Flickr
Bump stops and Small bonnet fixing
DSCN4774 by eric holm, on Flickr
Sits at right height now
DSCN4777 by eric holm, on Flickr
Drivers door being fitted:
DSCN4779 by eric holm, on Flickr
DSCN4780 by eric holm, on Flickr
DSCN4781 by eric holm, on Flickr
DSCN4782 by eric holm, on Flickr
All fitted now, but terrible alignment, professional help is needed
DSCN7816 by eric holm, on Flickr
DSCN7828 by eric holm, on Flickr
DSCN7833 by eric holm, on Flickr
DSCN7836 by eric holm, on Flickr
DSCN7837 by eric holm, on Flickr
DSCN7839 by eric holm, on Flickr
DSCN7842 by eric holm, on Flickr
DSCN7845 by eric holm, on Flickr
DSCN7847 by eric holm, on Flickr
cont...
21 Sep 2015, 4:33pm General Update
Thanks!
21 Sep 2015, 4:35pm General Update
Thanks but finishing post Is a fair distance away yet. It's going to be all about the detail for me.
21 Sep 2015, 4:37pm General Update
Thanks, I gained from shared knowledge, only right I should contribute.
21 Sep 2015, 9:07pm Mechanical Overhaul Chassis and Body
Hi Bill,
Thanks for images, actually a bit of 'flap' on that section would help as I get problems when opening the door fully as it pushes on that bottom edge, I've adjusted the door skins so they are as far back as possible, actually they stick a little when opening the door on the back section. Also I have pulled the front section as far forward as possible and even shimed it, so have a huge gap between door and front section, you can literally drive a bus through and it still doesn't clear. Also moved front section spring latches as far back as possible to try and push front section far toward as possible.
Then there is the height of the door and the front section, both doors are considerably higher that the front section, but must be sitting right as the bottom of the doors have a good size gap that I would expect.
So not sure, other than giving to someone who can sort it for me.
Don't get me wrong it doesn't have to be perfect, but I like the word 'Reasonable'. Currently it's not reasonable. :sad:
23 Sep 2015, 6:56pm General Update
Thanks, I'll consider that, although don't have welding equipment or any knowledge how to do that, but know a man who does :icon_smile:
26 Sep 2015, 9:18pm Chassis and Body
Ha ha, nice:becky:
Beer and skittles, before the gastro pub takeover! :wof:
Iv'e pretty much done what I can on the car now, will use it for a while and then when half decent weekend weather has finished will send for prepping and painting, so won't be expecting to post on the forum for a while.
Would love to go to Ferrari event at Beaulieu tomorrow just to see if I could get in past the entrance with it, but its the other side of the world for me, maybe next year....
27 Sep 2015, 8:07am General Update
Thanks!
Not roundabouts they are chicanes! :biggrin1: directly after a very fast straight! :laugh:
