The Kebab
By hurnleft · 213 updates · Dec 2014 to Jun 2017
October 2015
1 Oct 2015, 3:18pm General Update
Thanks Andy,
I'll fit a new horn button on the dash or centre console. I might use a start button, that would surprise any would-be joyriders.
1 Oct 2015, 6:09pm General Update
I shouldn't have shown that, it's top secret and still in the development stage. All I can say is it should be a big improvement on the tiny ashtray currently fitted. :eusa_shhh:
7 Oct 2015, 2:36pm Chassis and Body
I've just had number 1 coil pack replaced. The mechanic said it was damp around it. I've had the car out in some very heavy rain in the past and wonder if the gap around the centre bonnet may have let water in which has gathered there.
Not a problem for me now as the bonnet is sealed but possibly, for those that prefer to keep it as opening, worth sorting a rain gutter/seal.
15 Oct 2015, 2:02pm Engine Mechanical Overhaul Chassis and Body Interior & Trim
Not much visible change today but I've had an electrician here doing some jobs.
The horn which was originally on the steering wheel is now rewired to an 'engine start' button which will go on the console somewhere.
The high level brake and rear light is wired up and has a rear light cut out in case an MOT man doesn't like a central rear light.
The rear fog light in the rear window is wired. The hang down one will be replaced with one that folds out of the way and only shows at MOT time. There may be a cut out switch installed later in case there's an MOT issue with it.
Also the alarm has a new light and the second number plate light is now wired.
Next on the list is an outside opening passenger door as I know that's an MOT issue.
19 Oct 2015, 1:16pm General Update
Sounds fun, I may be up for that,
November 2015
8 Nov 2015, 7:51pm Engine Interior & Trim
I picked up the black seats and carpets this week.
One point that may be obvious to some but wasn't to me is that when I tried to fit it, the drivers seat electric motor would only move one runner. I knew it must have been ok when the guy I bought them off removed them or he wouldn't have got to the bolts. When I took it back for him to check, the answer was obvious to him, I'd picked up the front of the seat by what looks like a rod but is actually a plastic covered cable. It had pulled slightly out of line. I quick move of it and all now works fine.
27 Nov 2015, 2:48pm Mechanical Overhaul Chassis and Body Interior & Trim
Not much happening at the minute.
MOT repairs last week. 4 metal brake pipes and a couple of suspension bushes.
The current little project is to make the centre console a bit different.
I've checked what Geoff is doing and adapted his idea.
The heater panel now has mesh with an alloy backing with the horn (start) button where the clock was and the other panel will have 3 flick switches and the socket for the sat nav fitted.
The shortened console will have the mesh fitted at the bottom in a form that's not fully decided yet as I tend to make it up as I go along.
Big news is that I've booked it in for the start of Feb for the body to be finished and the paint job done (dark blue of some sort)
27 Nov 2015, 9:59pm Mechanical Overhaul Interior & Trim
I've looked at the chrome rings but at £20 for them, I'm having a look for an alternative first.
Partly because I'm tight and partly because I like to make bits out of other bits. The alloy is from a shop display stand and the mesh is Mitsubishi vent mesh and the back of an old heater.
Talking of James Bond, I've ordered these to go on the switches.
December 2015
28 Dec 2015, 3:34pm Chassis and Body
Good to meet you too, your "Lancia' caused a lot of head scratching as well. It's that patina paint finish, you can't fake it you know!
January 2016
11 Jan 2016, 9:37am Chassis and Body Interior & Trim
Hi all,
I've started fiddling about with the dashboard facia as tomorrow it gets changed to the black one so I needed to know if the eyeball vent idea would work.
I'm only making small changes to things, not altering to the standard of Richard from Nubodi and his excellent Beemarrari style alterations.
I've only done one so far as I had one spare net come with the new dash. The louvres were removed as a lock (they just unclip) and the main flap at the back refitted to it's side control.
After some cutting and filing, the Mazda MX5 eyeball went in ok. This left 4 corners to be filled, so I cut 4 little pieces of black plastic from a Saab door kick strip (which I had lying around in case it was ever useful) and boded them in. When firm, the eyeball was pushed back in and bonded.
The rear flap still works fine from the slider on the side.
The eyeballs came with the chrome trims which will probably be cleaned and reused, but first I've ordered some adhesive chrome strip to tidy up the black edges.
I'm off today to see the painter to check a couple of paint samples that he had mixed up in small amounts and is spraying onto some metal so the I can get a good idea of the coulour. I'll then pick one and the paint will be ordered.
12 Jan 2016, 1:35pm Chassis and Body Electrics Interior & Trim
The vent idea seemed better than it was as when the drivers side came out the old dash, I realised the light switch was part of it and the vent itself smaller.
I'd like to keep the original light switch to save wiring complications so I may put a blank where the vent was and fit my 'start' switch in there.
Dash and front carpet were swopped over to black this morning so I'm much happier about the colour.
Still got 2 more eyeballs so plan to fit those in the middle space as the car soon gets warm inside.
The paint samples were done so the painter sprayed both colours on the wing so I could decide on preference. Fortunately I chose the correct one as my wife picked the same one when I got home. It's not that easy to see in the pictures put the chosen one (front of car) has a petrol green tinge and the other is more towards a lilac tint. I'm really glad I didn't just choose from the colour charts as the colours look very different when on the car. I didn't want a metallic for ease of touching up paint chips.
17 Jan 2016, 2:03pm General Update
I've done a bit more with the air vents today.
The n/s is polished up a bit and stuck in the old dash for now.
The o/s was too small to fit an eyeball vent as I wanted to keep the original open/closed slider and switch. I've fitted a piece of mesh the same as I'm using in the centre console which will still work as a vent on the slider. The switch is to add a bit of of interest to it and will operate an air horn when I get around to fitting it.
I'm currently waiting for the sealer to dry on the centre vents then I can make the surrounds.
Just small things but they all move the project forwards.
30 Jan 2016, 11:02am Mechanical Overhaul Chassis and Body
Just picked the car up from Mark's as he's been sorting 1 or 2 things before paint.
The door handles now both work from the outside.
The bonnet opening issue has been sorted. The catches are all original but with the replacement of the springs with those from a Land Rover Discovery. It now rises enough on the catches to open from the outside. The top inside of the grille surround has been scooped out to make moving the catch easier and a stay from the same scrapped Disco added to keep it open.
As I'd been a bit paranoid about the bonnet staying closed down, Mark has added a screw in tow ring to a plate welded on the front of the chassis. This will be painted and left in unless I want the bonnet open.
He has ordered some thick alloy angle to make brackets so that the bonnet sides fit snuggly. These will be added later.
I'll start pulling a few parts off this weekend as it's off to the paint shop on Monday.
31 Jan 2016, 4:55pm Mechanical Overhaul Chassis and Body
The weight of the bonnet with the small centre bonnet on, is too much to for the springs to lift the bonnet off the catch, so WCA has a wedge which he puts in the handle to keep it in the open position while he goes round to the front to lift the bonnet. The Disco springs are stronger and lift the bonnet enough.
Hope that makes sense, Bob.
February 2016
4 Feb 2016, 1:05pm Chassis and Body
The car is stripped and they had just started on the bodywork. I'll pop in again on Monday as Mike who built my truck will be back from holiday and will decide who best to use the new fittings to mount the door skins.
Meanwhile it's clean/polish/paint the bits I took off.
8 Feb 2016, 12:13pm General Update
Photo's of progress as of today. They have a plan now for the skins so I'll report back to you on what they end up doing.
8 Feb 2016, 6:49pm Chassis and Body
He may be big and he is camera shy but he's good at bodywork and will work for food !!
11 Feb 2016, 2:26pm Chassis and Body
Door skins are now sorted and bolted in place.
The car will get a few unwanted holes glassed in and the rear light areas sorted then it's sand, sand, sand as the guy who does most of that is back next week.
They will also sort the bonnet to door edges gaps and bonnet lower to door alignment then.
19 Feb 2016, 12:18pm Chassis and Body
It keeps making progress towards paint.
19 Feb 2016, 1:58pm Chassis and Body
Almost certainly staying blue although the painter did say today that up to the minute he orders the paint, I can have any colour I like….so who knows.
