Seanicks Unnecessary Life Complication
By seanick · 183 updates · Oct 2012 to Sep 2019
December 2012
14 Dec 2012, 8:50pm Chassis and Body
Heres another 'dangle from the roof with one hand shots
spot the mods.......
I had a bit of off white spray so gave it a dusting to see how it looks. I much prefer it without the front vents. I think they distract the eye from the overall shape, and from the non-grill.
Managed to lose them in three fills and a lot of long boarding. I use an aluminium strip laid over the area I am fairing as it easily shows the lows. For tight rads I use a hacksaw blade, then mark them with a pencil. Makes filling quicker!
Looks like...
Octonauts, to your service! Lets do this!
Just trying these tailpipes for size...
14 Dec 2012, 10:04pm Mechanical Overhaul Chassis and Body
I may put side vents just behind the front wheel, but I change my mind quite often! Not trying to create a replica just a mixed coupe with some Fewawi-isms.
Yes to a stick on numberplate. I have a 1963 plate going on, thats A reg first time round, black and silver (for show plates, of course).
Weathers a bit warmer for your painting now.
17 Dec 2012, 9:43pm Engine Mechanical Overhaul Electrics
After a lot of thought, I have shelved the plan of making the front flip. I think its possible, but not for my time scale. About 18/20 bolts takes it off anyway, so seems silly to pursue it. :yield:
:yield:
Spent an hour or so relocating the expansion tank to the other side, and twiddling the brackets for the fuse box and locating it over the suspension turret.
Phone exhausted, so no pics!
19 Dec 2012, 9:26pm Chassis and Body
I want hinges, but have played around with the old bonnet hinges and dont think they will work. I may try the boot hinges or look around the scrappy for ideas. Maybe cantilever like on early escorts?
Like mist people time is short now, and it will be Jan before I refocus on it.
I did go Christmas shopping today, and came back with a nice 3M longboard and the paint!!! :laugh:
20 Dec 2012, 2:15pm Chassis and Body
I have bought hi-build primer, which is grey.
Still can't make up my mind over top coat. Favorite so far is the lime green, or a dark metallic silver....sort of graphite colour. However I have never sprayed metallics, so it might be a disastrous choice!
Any colour suggestions anyone?
20 Dec 2012, 9:43pm Chassis and Body Interior & Trim
Had a go a the bonnet hinges this eve. Ended up using the boot hinges, removing all the bits and just leaving the main arm. Made a bracket out of 3/4 by 3/4" angle, and bolted it to the body using two existing holes, one of which has a captive nut underneath.
I think it will work, as the pivot point is forward of the bonnet front. However I have yet to try it as my bonnet inner moulding is still in the garden! I needed to trim the inner flange to get clearance. It will need a packer on top. I may glass a steel plate onto the bonnet and weld on a couple of lengths of studding, the the bonnet can be adjusted up or down without shims.
OPEN
Closed
Body moved fwd a bit.
Lil bracket with a squirt of matt black.
20 Dec 2012, 9:59pm Chassis and Body
Mmmmm, not a colour I had thought of, but I have seen E types in that colour. Mmmm, It quite appeals. Thanks!
ps It would go over the grey primer a treat!
20 Dec 2012, 10:10pm General Update
That was my initial thought too, a nice silver,, but I think yellow would scream KIT CAR!!.
The only problem with silver or any metalic is my ability to apply it.
Maybe pale yellow would be okay.
Blue does not really appeal to me, although I do have some blue in the interior, I will have to live with it for now.
As for lime green....possible the most famous 250GTO ,Stirling Moss' car which sold this year for 22.5 MILLION...
20 Dec 2012, 10:44pm General Update
Oh yes, this is where I have relocated the expansion bottle.....
Still got to make som little brackets to hold it there....
27 Dec 2012, 8:37pm General Update
Hi Hammy. Thanks for your encouragement:eusa_dance: Christmas has slowed things up a bit..but raring to get back to the front section. Should be on it by the 30th. I am in Emsworth, PO10.
27 Dec 2012, 9:00pm General Update
welcome any time...after 29th!
30 Dec 2012, 6:47pm Chassis and Body
Parraelle bonnet hinges in the Research and Development lab.....[IMG]:twitch: [/IMG]
30 Dec 2012, 11:43pm Chassis and Body
Whilst I am sure this could be done in CAD in an instant it took a bit of old fashioned trial and error.
This should lift the bonnet front up and over the rad filler and up to about 50°.
I plan to use the existing studs that bolted the raising light mechanism. make a simple plinth from angle about 5" high to mount the hinge on.
Closed position.....
Open position.....
January 2013
4 Jan 2013, 7:47pm Chassis and Body Electrics
[SIZE="3"]Thanks Peeps i, however I made these up this afternoon.....they bolt onto the old headlight mounts where there are two 8mm studs. They lift the bonnet right up and well clear of the front edge of the body. They need a bit more drilling for weight loss, but they work well, and rake the bonnet to approx 60 degrees. With a bit of tweaking they should go to 80 degrees.[/SIZE]l[IMG][/IMG]
The end that is cut at an angle will have s plate welded to it to mount to the inner bonnet molding. I will have to put some extra bumps in to do this, but will probably use some of the inner molding I have cut out just repositioned. I have had to cut a lot away to get clearance for my sporty bits!
So thats closed.....[IMG][/IMG]
And thats open!
So thats about 20 hrs of thought and versions mk1 to4, and two hours to make the final thing!"
That's all until next week as I am I/C children this w/e.
4 Jan 2013, 10:45pm General Update
Thanks Chris, need to do a final fit first but there is so much lift initially it should be fine. May get that done sunday eve, so hang on to your hinges until then !!!
6 Jan 2013, 11:19pm Mechanical Overhaul Chassis and Body
Thanks Peeps, yes I think Brunel was pretty cool! They are pretty strong. I could get air lifted bout by them if need be. I have drilled them out a bit to save a few grams.....
Fitted them this eve.
Good idea John, all I can come up with is either wing nuts on the mounts or it would only be two nuts per side to split the hinges. I might weld up two of the bolts. Good idea!
Chopped out the middle of the bonnet inner molding (sorry Chris) to get clearance over my suspension brace, but also to use sections if the molding to add new hinge mounts further out....[IMG][/IMG]
Tomorrow Ill glass those new bits, glassing over some 6mm plate to tap into.
7 Jan 2013, 12:11am Mechanical Overhaul
Thanks, those saabs do have wacky hinges, but to ne honest I am (honest!) Enjoying re-inventing the wheel!
7 Jan 2013, 10:32pm Chassis and Body
[SIZE="3"]Fitted an 8" strip of 4mm steel into the new bumps for the hinges. Bedded them on filler, then glassed over the top with 6 layers.[/SIZE]
[SIZE="3"]Glued the inner and outer skins of the bonnet together with a polyurethane constructional adhesive. Hope its the right shape! Had some foam so filled the voids in a bit.[/SIZE]
7 Jan 2013, 11:54pm General Update
Um....we have more...these are the small ones....can probably manage about 130, plus sash cramps....:shocked:
