Tuesday
I have been fairly busy doing all sorts of stuff, and also working on my build.
I have finished the heating ducts in the dash, which seemed to take forever.
They have much narrower pipes to feed the hot air to them than before, but I have used pipes as wide as I could, given the confines I'm working with.
They should work okay, but it may take a little longer to demist than before.
Bearing in mind that 90 per cent of the time I should be driving around with the roof off! (What roof?)
When I make the dash, I want my start button at the top, the ignition key under that, and the choke button under that. It seems logical to me.
At present the Spitfire choke cable is too short to reach, so I ordered a generic new one at 6 feet long.
It arrived today, and I spent an enormous amount of time modifying it to look like the button in the real XKSS that occupies that position.
I had to file all the engraved letters off, then cut and file it to look like the XKSS button, or more like it than it did to start with at least.
The material is very resistant to being filed or marked in any way,which made the work hard to do, but it will pass a not-too-close-inspection now.
I am not even sure what function the original button performs, but I would guess at a manual water pump for the wipers. It has "push" written on it.
I have an electrical one so do not need that switch anyway.
Here are some pictures.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
