Crimson rodent cycle, or redratbike as you prefer:-)
In answer to your question, what am I trying to achieve? I sometimes find myself asking the same bloody question, and at times I'm not even sure..........
Right, here are some pictures and drawings, which would not win prizes, but hopefully will explain what I'm trying to do, with these bent pipes in order to make a thousand quids worth of XKSS bumpers.
As I said once before, I am not keen on the original XKSS bumpers at all, and want mine to be the shape in my pics.
They are purely for asthetics, (a bit like the real ones then!)
Since I last posted, I have had another re-think, and have decided on pipes with a diameter of 1.5 inches, and not the 2 inch ones.
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]On another note, I started work on assembling the doors today, which threw up even more complications, (a bit like Paul I guess!)
When I stuck the alloy plates on the inside of the door skins, it seemed to somehow flattern out the curve, so when I mate up the skin to the door, it takes quite a lot of pressure to bend the skin around the frame and hold it there.
So much pressure, in fact, that I am thinking that bonding alone may not hold it, as it wants to spring open all the time. I did not really want to use rivets, as it would not look right.
Then I came up with the idea of trying to re-bend the skin to the correct shape, and to that end, I have clamped the skin up, and will leave it that way for a day or so to see if it will reshape.
I will post the answer in due course........
