SwiftyDS's MRS200 Build
By SwiftyDS · 203 updates · Dec 2016 to May 2020
October 2019
30 Oct 2019, 5:10pm Mechanical Overhaul Chassis and Body Electrics
Redid the passenger door handle rod yesterday and have to say it was much simpler and quicker now I had it sussed from the drivers side. Also the wire rope grips make it much easier to fit.
Door card back on the passenger side.
Bit more tidying up of the inner door area with some matt black paint then I just need to get the drivers door card on. Aiming to get it MOT’d next week - hopefully should be ok. Main areas of concern are the headlight alignment due to how I’ve mounted the Golf MK2 lights and bonded then into the headlamp cowls in the bonnet (I have aligned then as much as I can at home) and the handbrake efficiency which seems to be problem with rear callipers on all MR2 Roadsters from what I can see.
Will post an update on progress once it’s booked in.
November 2019
2 Nov 2019, 9:58am Mechanical Overhaul Chassis and Body Interior & Trim
I didn’t manage to spend as much time on the remaining jobs on the car this week, so I’m not quite there yet with booking it in for the MOT.
I noticed that the thin black vinyl coach stripe that I’d used down the indent on each side of the car was peeling off at the edges and I just couldn’t get it to stick. Also the gloss finish of this wasn’t contrasting well with the matte white. So I decided I would paint the stripes on. Wasn’t too difficult with a small square brush and masking and like the rest of the finish will do for now.
Not many opportunities to get the car out of the garage with the weather being awful, but I did need to turn it round to put the door cards in and finish off the black paint on the inner door edge on the drivers side. What I have noticed is that the front mudflaps are still catching on the tyres on full lock - you can’t really see in this picture but I will have a go at trimming back the inner edge otherwise I’ll remove the front ones for the MOT.
Drivers door card back in and the inner door edge tidied up with matt black paint.
Just needs a good clean now inside and out, front mud flaps looking at and another pre-MOT check. Aiming to book it in for the end of this coming week.
3 Nov 2019, 5:52pm Electrics
Thanks Jack. All cleaned up now inside and out and all the little jobs completed ahead of the MOT.
I just want to have another go at the headlamp alignment given this was tightened up back in 2016 for the U.K. MOT regs. Aiming to have this done tomorrow/Tuesday and will book it in for the back end of the week.
8 Nov 2019, 2:35pm Chassis and Body Electrics
MOT passed !
After nearly 3 years building, my MRS200 replica passed its MOT this morning at the first attempt.
Knowing how much the MOT changed last year I have to say I wasn’t that confident it would pass first time despite all the checks I’d done. In the end the only issue was with the headlamp alignment which I had been expecting. I went armed with a toolkit and it’s an MOT centre I’ve been to before with kit cars. The tester was great and showed interest in the car from the outset. He was quite happy for me to make adjustments to the headlamps - i had set these up at home so they were aligned both sides but I couldn’t really get the height of the beam accurate which is where it needed adjustment. Luckily I’d built some adjustment into the brackets holding the MK2 Golf units to the back of the cowls which was enough.
Very happy bunny and the car ran great there and back which was a good 10 mile first run. Taxed it online as soon as the tester updated the pass status and all set to go.
He did record an advisory as to the car being ‘heavily modified’ which I can live with.
As you can imagine I still have a long list of ‘improvement’ jobs to keep me busy but at least now I can enjoy it on the road. I also do still plan to get a professional paint job but the stickers and vinyls are holding up just fine so far so no rush for that.
I will keep updates coming for those who are interested but shift this now to an on the road thread.
A big thank you to everyone who has shown an interest in my thread over the past 3 years and especially to those who’ve provided help, inspiration, feedback and ideas along the way.
8 Nov 2019, 7:13pm General Update
Thanks guys for the positive comments.
Yep the guy felt he had to include an advisory on the grounds it was ‘heavily modified’. No issues just felt he was sort of covering his own back. Unfortunately the spelling of this came out as “ this vehicle is Hefley modified“ !!
Now if only it was a Hefly MRS200 kit :-)
12 Nov 2019, 9:37am Chassis and Body Interior & Trim
Having loads of fun with the car now I can finally drive it on the road. Weather hasn’t been great so it’s pretty grubby - I gave it a good coat of resin wax/polish to protect the stickers as best I could given these are just applied to the polished up gel coat for now.
Anyone who has any recommendations on good protectors for this set up with gel coat etc until I get it painted just let me know on the thread here.
Went to fill up with petrol over the weekend as I’d been topping up the tank during the build with fresh fluid from a jerry can but worked out probably half of the half full tank (1/4 of the tank) was probably still the fuel I had in it when it was last on the road before I started the build back at the end of 2016. Loads of folks came over as I was filling up and paying ... one guy was on his way the NEC Classic Car show and thought it was a real one .. even when he was close up :-)
Decided I couldn’t live with the Nav Pod I’d built a small 7” tablet into for sat nav/OBDII gauges and had sat in the cubby hole space in the MR2 dash. I found a folding smartphone holder on Amazon which looked just the job for a spare Android phone I had lying around. Means I can put the lid back on the cubby hole in the dash, and when the phone isn’t in the holder, everything folds down and the cubby holder lid closes.
There’s quite a bit of lag with the ODBII Bluetooth dongle I’m using and the app (Torque Pro). Will have a play with the set up and also try another spare Bluetooth dongle I’ve got.
Again, if anyone has experience of Torque Pro on Android and can comment if this lag is normal I’d appreciate it.
12 Nov 2019, 10:24am Chassis and Body
Thanks Mick - also following your latest build which looks great.
15 Nov 2019, 11:01am Engine Chassis and Body
Managed to get out and about in the car quite a bit this week despite the weather. At least the fact the kit keeps the MR2 doors / windows as-is means it’s water tight, and so far (touch wood) the bottom the door where it had to be cut down to fit the MRS200 door skin is staying dry.
It’s surprisingly refined with the MR2 windows up when driving but not so refined that you can’t hear the induction roar from the kit I fitted. That, together with the non-standard exhaust I fitted early on in the build, means it feels faster than the MR2 donor. I need to find a quiet straight road to check if it is actually any quicker :-)
I’ve got a few areas I’ve spotted through the road tests so far that I need to take a look at over the next week or so. The front engine undertray has come away - not enough to drag but on inspection at some point the retaining fixing had been lost and replaced with a cable tie that had snapped - missed that one in all the checks but easy to sort. I’m also still not 100% happy with the fit of the drivers side rear light assembly where it meets the wing area - it needs shifting towards the centre or the car by about 5mm to sit better. I need to open up the aperture in the rear clam a bit so it moves over.
Being white means it only needs the slightest bit of wet or damp on the road and it looks filthy ! At least the arches front and back look a bit more ‘lived in’ now :-)
18 Nov 2019, 2:22pm Mechanical Overhaul Chassis and Body
Yes Kon that is a bit of a mud trap just behind the flap - but the wheel arch liner curves in towards the bottom of the wing so the pocket isn’t that deep.
I’d not thought about it until you pointed it out so will keep an eye on it and keep it cleaned out. Many thanks
24 Nov 2019, 9:34pm Chassis and Body
Early Christmas present - the black lamp pod cover.
The lamp pod itself came with the kit from Tribute but I didn’t really want the 4 extra lamps and weight on the bonnet. Wasn’t going to fit it then saw some pics of the original Group B cars with the black lamp pod cover and quite like the look.
So the lamp pod assembly was brought down from the loft and I found a supplier for the black GRP pod cover.
I need to polish up both the pod and the cover and work out a way to mount the pod on the bonnet so it’s removable without leaving too many holes - ideally no holes!
I don’t really want to fit the lamps as I will never use them so it’s really about what it looks like - bit sad I know!
25 Nov 2019, 9:25am General Update
Thanks Jeff - I’ve stayed away from waxing it so far so hopefully should be ok. Will just keep washing / wiping it down with microfibre towel.
25 Nov 2019, 5:50pm Chassis and Body
Thanks Andy - I was trying to work out how I could minimise the bolts and holes! Don’t have the space to store a spare bonnet so needs to be a bolt on/off job
26 Nov 2019, 7:58am Chassis and Body
I’ve had a couple of suggestions now about magnets - to be honest I thought there was no way I would find anything strong enough. I know I’m not fitting any actual lamps but the GRP for the lamp pod assembly itself plus the cover is quite heavy.
Do folks think magnets would really hold this...plus the fact it’s going onto the front of the bonnet where it slopes down ... where the Shell sticker is?
27 Nov 2019, 6:54pm Chassis and Body
Been looking at the magnet options - never knew the kind of weight rating neodymium magnets could hold and not too expensive. Going to order a couple of those and see how it works first.
If that won’t hold it I’ve worked out a mounting system where the holes are concealed at the back of the bonnet vent and under the return edge at the front of the bonnet.
Thanks for all the comments/feedback - clearly proved an interesting topic :-)
28 Nov 2019, 9:32am General Update
Thanks - just found some relatively small ones that claim they can hold 34kg!
December 2019
1 Dec 2019, 11:46am General Update
Thanks Paul - it’s certainly getting dirty!
A few pics from earlier today to prove it’s also capable of carrying the weekly shop .....
2 Dec 2019, 1:48pm Engine Mechanical Overhaul
Thanks for the kind comments guys - it certainly attracts attention on the road and when stopped !
One other thing the shopping trip did prove was that it can cope with speed bumps ok - I was worried about the rear under the engine where it’s so low on the coilovers but seemed fine taking it steady and slow over the bumps.
28 Dec 2019, 10:55am General Update
A belated Merry Christmas to everyone and an early Happy New Year.
Managed to get the car out today for the first time in a couple of weeks. Great fun and managed to get a couple of different location pics.
Had to get a couple of provisions from the shops on route and must have spent about 10 mins in the car park when I got back to the car talking to the onlookers and photo takers - I need to do better at factoring the attention it gets into my route planning!
30 Dec 2019, 5:17pm General Update
Thanks guys
January 2020
4 Jan 2020, 9:38am Chassis and Body
On one of my recent trips out when I was parked up someone mentioned there was one of the original 1986 Rally Spec cars up for sale for over £500,000.
Found this on YouTube last night showing the same car ....
https://youtu.be/2KLlbBnKnwk
Not sure if I had that kind of money I would actually spend it on a real RS200 - reckon I’ve spent less than a 50th of that price getting mine to where it is today - nowhere near the same performance but puts a smile on my face :-)
