exhaust
8 Jan 2007, 3:03pm
Having fired up just b4 xmas I am sorting the exhaust system.I have planned on two side mounted exhausts, but these will be supplied from pipes under the car ,not thru the side louvred panels.Anyone got a suggested supplier, and any idea were to purchase different bents and lengths of pipe? Cheers
9 Jan 2007, 8:17pm
Personally I would avoid custom chrome, that's part of the reason I've build my own exhaust.
[url]www.merlinmotorsport.co.uk[/url] sell bits to make your own re-packable side pipes. Aimed more at the 7 replica market I think.
10 Jan 2007, 12:52pm
exhaust
Thanks Patrick;have thought of using a cobra replica side exhaust,just bringing one pipe put from the underside of the car.Any thoughts?
10 Jan 2007, 1:24pm
Personally I am not to keen on side pipes. Having had one on a previous kit the problem is you soon get pretty fed up of that noise in your ear the whole time. I would use a rear exit every time. You could try the TR6 rear box setup that I am using if you wanted to go the rear exit route. Just needs 2 straight pipes and the TR6 rear box - very simple.
10 Jan 2007, 3:10pm
exhaust
I have been following the pictures of your set up, and Patricks.I am worried re ensuring the sva rules on fire safety with the tank above it, and about clearance below the e30 trailing arms.
10 Jan 2007, 3:36pm
exhaust
Thanks patrick, and robin, I am being slowly converted to rear set up....have been looking at MGF and Mr2 back silencers on ebay...I wonder would this fit?
10 Jan 2007, 4:37pm
There's no reason those wouldn't work - the only thing you need to watch out for it that the input pipe(s) are not smaller than the stock size for you engine or you'll end up choking it.
The mufflers I went for are straight through glass packs which do result in a louder than stock exhaust, but very free flowing.
The main rule is the bigger the muffler the quieter, and the more internal baffles the quieter. The trade off is baffles = less flow = less power. So its a balance between sedate and power - I went for best possible power (with a bit of show factor) with mine and I'll probably get a slapped wrist at SVA time unless I plug it up some how. :)
10 Jan 2007, 5:37pm
Easier to use something that someone else has already used - at least you know it will fit. Here is a picture of the system I used with a TR6 box - can't get simpler than that! http://myweb.tiscali.co.uk/martinclan/images/exhaust1.jpg
I had my (stainless) TR6 box lying arround from a previous project so it was free. Apparently they are quite expensive now - but still cheaper than buying something that doesn't fit!
Just looked it up - stainless back box for TR6 £135 - not to bad. here is a link
http://www.rimmerbros.co.uk/cgi-bin/rimmer?findpart&PartID=GEX3391SS&Page=triumph/tr6/exhaust
