Wiper arm from motor
7 Jan 2007, 7:28pm
In the manual it shows a piece of meteal being let in for the the arm linking the wiper motor to the wiper arm, can anyone tell me how long that should be.
7 Jan 2007, 7:51pm
Steve, I was told that it is the standard control arm but shortened and re-crimped back on and that the length was determined after conecting the wiper to power and in the park position!
I am sure someone else will clarify
Craig
8 Jan 2007, 12:18pm
Hi Steve.
I see a great little idea from bigrich.
He cut the wiper arm rivnutted two rivnuts into the cut sections. Then used a threaded rod with two locknuts. That way it could be adjusted as needed.
cheers
John
8 Jan 2007, 7:17pm
thanks Guys, I dod not mean to mislead you, I am talking about the link that bolts onto the motor via the splined sprocket, and it about 2.5 inches long. I understand that needs altering, or has that now changed.
Steve
8 Jan 2007, 9:56pm
On mine (factory built), the link attached to the motor is approx 7.5cm overall with the pivots approx 5.5cm apart. It gives a full sweep of the screen.
Phil
10 Jan 2007, 7:40pm
Thanks Phil for your help.
Steve
