Started my engine for the first time today in my Marlin BMW Sportster. (Last time it ran, it was in the donor car about three years ago!)
It didn't exactly burst into life and took a fair bit of coaching to get going. Eventually I got it to run on 4 out of 6 cylinders? I had put oil down the spark plug holes when it was laid up, to stop the pistons seizing in the bores and forgot to clear it out today! doh!
Exhasut note sounded great but that may have been because two cylinders were not firing??
I think I have 'oiled-up' two of the plugs, but I am happy that all the basics worked and after warming up, it ran on tickover on its own. Ran out of time and light this afternoon, so will have to investigate next startup. No obvious leaks, but will check it all over next time.
Charging light went out when first started but I noticed that it was back on when I was finsihing up, not sure if the alternator has died or something else to investigate.
Low pressure fuel pump vibrates like crazy so will have to look again at how it's mounted.
Another significant milestone in the build completed, now onto the dashboard, etc.
Latest pictures here.........
http://www.flickr.com/photos/peters-bmwmarlin/
regards
8 Oct 2006, 10:17pm
Another running engine is good news!
- Will the tips be inside of the rear bumpers? I've read that SVA requires them to have radius if they stick out of the bodywork - I've still not figured out if that includes bumpers or not.
