Built by a professional coded welder
Completely finished no welding required built for a Ford Sierra based car Engine and gearbox mounts done. Comes with bolt on rollover bar, bolt on differential brackets front top and bottom wishbones and camber adjustment ball joints
Rear wishbones top and bottom with camber adjusters rear upright hub carriers for drum brakes.
All wishbones hub carriers fully polybushed with stainless crush tubes Haynes roadster pedal box and clutch cable Rear wings in yellow (fibreglass), mushroom inserts for Sierra front uprights Sierra drive shafts rear brake back plates and drums Escort Radiator and electric fan rubber engine mounts rack clamps.
There are photos of the chassis on facebook marketplace if you want a look . Just type in haynes roadster The facebook add seems to have disappeared so if intarested message me and i can email/text the photo.
The photos are back on facebook now if you want to have a look.
