Due to needing cash for a mortgage deposit, I now need to sell my GD427 Project.
Would prefer to sell the lot in one go but may split into sub assemblies but not individual parts. Would sell the lot for £8500 and would consider delivering anywhere in uk mainland.
Not a lot has been done but a fair few bits have been gathered ready to start, namely:
GDJag mk4 Chassis, Powder coated Silver with Roll over hoop brackets and bolt kit
Steering Rack Assembly with Track Rod Ends and Mounts (all bare metal painted)
Brake line set (fitted)
10mm rigid Fuel line (fitted)
Flexible brake hoses
6 adjustable dampers and springs
Hand brake cable
Gearbox Mount Bracket
That little lot costs £5K + plus and about 10 months wait after order.
[/B]I also have the powerplant:
LS2 from a Vauxhall Monaro 2005 with 45K
Complete with:
ECM, all Sensors and connectors (except O2 sensors) includes MAF
Modified Loom with redundant circuits removed
Alternator
Cleaned, painted
Spare Monaro loom, headers power steering pump etc.
This needs a new clutch and flywheel (I can put you in touch with someone who has a LS7 Clutch assy inc Flywheel for sale at £450).
GD engine mounts.
Thermostat housing with GD for welding in straight ahead position
I also have all the pinout and wiring diagrams for this motor (there are some differences from the GTO and earlier LS1)
Basically everthing you need. With purchase receipt (not nicked!)
T56 Gearbox (TEUT 2066) with GD flexible G'Box mount to suit Chassis
Cleaned and painted
Braided remote Bleed line and Slave line
Shifter with GD for welding in forward position
For The above LS2 and T56 will sell separately for £5000 no offers
Donor Jag Items:
Suspension items and drive shafts etc. stripped, cleaned and zinc primered
XJS Power lock Diff 3:54 cleaned and checked for wear (all good), Painted.
Rear Hubs (not yet refurbed)
Most of the bits from the original strip down (nuts bolts shims washers etc. where they may be serviceable)
Front and rear Callipers (not yet refurbed)
XJS Hand Brake
XJS Log Book
Jag bits I will sell for £500 OVNO
All Receipts.
If you're just starting out, this could save you a shed load of time and cash!
Tim
25 Feb 2016, 10:52pm
