Wire wheels
13 Aug 2014, 1:21pm
:help:Anyone know the best way to fit 15 inch wire wheels to Spitfire 1500 hubs ?
13 Aug 2014, 3:05pm
A set of adaptors for MGB 14" or TR6 15" (and similar wheels) are readily available. An example here -
http://www.ebay.co.uk/itm/SAMMIO-SPYDER-WIRE-WHEEL-ADAPTORS-SET-OF-4-HERALD-SPITFIRE-GT6-VIT-BASED-KIT-CAR-/371082702587?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item566640aefb
Other specialists can also provide - MWS is probably the best known -
http://shop.mwsint.com/product_details.asp?id=25
Good luck!
13 Aug 2014, 5:58pm
The Spitfire hubs for 13" wires have shorter splines than the MGA/MGB/MGC type, so larger wheels won't fit them. When a bigger wheel is pushed fully onto the hub the thread for the spinner is still inside the wheel giving you nothing to screw the spinner on to.
The MWS adaptors are excellent quality and will take any of the MG A/B/C wires giving you a choice from 4"x14" 48 spoke, through 4.5"x14" 60 spoke (MGB and cheap as chips on ebay) to 5.5x15 72 spoke (typically £200 each new).
Just bear in mind that the TR4/5/6, Jaguar and Aston Martin all used different splines so won't fit the MG adaptors.
14 Aug 2014, 6:57am
TR6 72 spoke 15" are the same fit as MGB. It's not an uncommon upgrade amongst the B fraternity.
Chic Doig's eBay ad says that they are good for TR6. I may be missing something; it wouldn't be the first time.
As T says, Jag and Aston are definitely out of the equation.........unless you get some adaptors made.................
14 Aug 2014, 7:29am
Oops, I stand corrected. I was led to believe that the big TR's had a different spline setup a while back but never really checked up as I was happy with the cheap MGB wires.
16 Aug 2014, 9:20am
Thanks
Thank you for all the info. Daft, but I never thought of looking on e bay
