Floor Pan & Bulkhead fixings
30 Nov 2005, 12:55pm
Hi....
Now getting to grips with the kit and have sorted out my build plan.
1st question (if anyone can help)....is it necessary to use rivnuts and machine screws for the whole of the floor pan or can the galv. sheets be bonded and threads tapped into the sq frame? :eusa_doh:
What's the best solution?
Thanks
Rich
30 Nov 2005, 2:40pm
I have blind pop riveted and gunked the large sheets and put rivet nuts in for the centre panels because they mite need to be removed at some time
My bulkhead panels are blind pop riveted and gunked as well
Hope this helps :biggrin:
1 Dec 2005, 9:09am
As Big_Fella - panel bond and rivets for floor panels and bulkheads. Centre section needs to be removeable, so rivnut, screw or bolt in.
The centre section won't go on for a while, but I am using silicon sealant on these panels to keep water tight.
1 Dec 2005, 12:56pm
Thanks....I'll grt the Tigerseal bought.
Rich
