Had my first go in a kitcar today and I'm hooked. It was a Caterham Seven and the problem is I found it was a bit tight around the shoulders and legs.
Does anyone have any suggestions for kits that have a bit of a wider cab to accomodate my larger frame. I'm 5'11'' and found that I was looking right at the windscreen frame for the majority of the run too.
The first two on that list also do additional publications that list and compare the different kits, so that should be just what you're after. I remember from a few years ago when i was going through what you are now, that they give you just this sort of information!
