An average socket set
An average ring spanner set
An average screw driver set
I think you need those just to get through life in general if you own a house/car/bike or boat
A jigsaw for trimming window surrounds an gtp panels, but you could use a hacksaw or pad saw.An electric drill for er hole drilling
Set of bits for the above. Again a usual household tool.
Trolley jack and a pair of axle stands sanding is handy, but not nescercery. If you are into cars you probably have these.
An electric sander is nice, but not nessercery. You get a better finish with long boards and hand sanding wet.
Volt meter
I reckon most of that would nit cost a lot if sourced at a car boot. New maybe £150?
This list is not exhaustive, I just cannot think of anything else!
Volt meter
Nick, you have beaten me to it again! Your list is only missing the pop-rivet gun and electrical fittings crimper.
I'm sorry. If I spent as much time working on the car as I did on this forum my build would be finished by now......te he.
Had a great time at Goodwood today, with two sessions on the go kart's with some mates so they did a grid start for us.....chaos!
Went in the Morris and the Burlington, with family co-drivers.
Finished the final details on the Burlington like rear mudguards and some front suspension covers, but just have to reshape the exhaust where it touches then its sort of finished for now. Only finished those bits friday. Then will start on my 250 this week....shock horror, even though I am still waiting for my wheels.
You've missed out an angle grinder with 1mm cutting discs and flap-wheel sanding discs.
I'd probably say that on my Sammio build the angle grinder is the power tool i used the most for cutting / restyling / grinding / sanding / shaping etc. and while the kits are different the "type" of build is similar so i'd imagine the type of jobs are similar?
The 1mm cutting discs go through just about anything with amazing ease and saved me SO much time and effort! And those flapwheel discs were brilliant for shaping glass fibre, as well as cleaning up metal and were more friendly than grinding discs when necessary!
I agree with a grinder (grindette, 4") being handy (I have four, to save changing from cutting to grinding to sanding etc) and you could sub one for a jigsaw as it has more uses, but, it will not cut fair curves very well, so for trimming GRP I prefer a jigsaw with a metal cutting blade.
Flap wheels in drills are simply horrid, sooo diy ;-) There you are much better off with a sanding disc in a grindette. Sculpt away!
Dont forget the PPE ! I have been sanding and cutting and GRP is nasty stuff, disposable dust masks, decent glasses and disposable gloves. Overalls are a good idea so you dont take it into the house A Hoover is useful to keep the dust down. A pair of tweezers to pull the glass splinters out of your hands while you watch Emmerdale. Buy decent sand paper its much better value in the long run. Goodluck
Sound advice Roger, for everyone, you only breath in GRP dust once before you buy a decent mask.
