Alex's TVR/250 Build
23 Sep 2012, 6:07pm
We have just started this build for Alex. He originally asked about an MX5 conversion with a stretched wheelbase and bigger engine installation, but after some discussions the logical step was to start with a longer/more powerful base car, hence the TVR 350. The original outer body panels will be cut off of the TVR and one of our MX250 kits offered up. A very quick Photoshop overlay shows how the unmodified panels should fit.
Much chopping and changing will follow over the next few weeks. We have made a start by stripping the TVR.
And I couldn't resist cutting off the rear panels in a spare moment on Saturday!
MX rear end panels roughly in place.
23 Sep 2012, 9:37pm
I think this is going to be fantastic. I also think that you could get away with the original screen. Those few extra inches of wheelbase and larger wheels look spot on. What is the plan re rear vents ?
Just as I was about to bond my body on too........
Lastly..... Is that Secma quad in for a body kit too? :-) :icon_twisted:
24 Sep 2012, 8:49pm
Hi Nick
The windscreen and frame will be going, its just too flat and isn't far enough back. Rear vents depend on Alex's choice.
It's not a Secma quad in the background, but a Renault Twizy electric car! And yes it is getting a re-body, subject to design approval of the customer.....
More progress today with the TVR front being stripped and a quick trail fit of the new front end panels. More trimming needed!
24 Sep 2012, 10:18pm
More trimming needed....but already looks a good fit...
There is a B reg 280 on fleabay for 1750 btw.. 70 miles .
Finally sorted the wheels, I hope!
28 Sep 2012, 8:18pm
More stripping down and trimming of the TVR outer panels. Doors removed, door pillars and windscreen also removed.
TVR side impact protection will be retained and modified to fit new doors
Trail fit of panels is now much better
Side profile is good...
But could be better...
17 Dec 2012, 9:18pm
This project is now back on track after a break requested by Alex.
Once the trail panel fit had been carried out Alex paid us a visit to discuss how the project would progress. It was decided that the scuttle area and windscreen needed to be pushed further down into the bulkhead. So more trimming of the bulkhead was required.
With the trimming complete the panels could be refitted. The centre of the bulkhead and the heater will need to be modified. The brake reservoir will also have to be repositioned to the centre of the bulkhead and the expansion bottle moved inboard slightly.
Repositioning of the windscreen has improved the front wheel arch gap and the curve of the top of the wing into the scuttle area.
17 Dec 2012, 9:29pm
Rear wheel arches have been opened up (part left is currently a mounting point)
Side window openings were also increased in size, the rear edge of the opening will follow the line of the lower door shut.
The front edge of the door has been moved back, lengthening the front wing. The side profile is now greatly improved.
17 Dec 2012, 9:47pm
The headlight/grille area needed to be dropped down to bring the front valance more in line with the door sills.
The radiator needed to be canted forward to give clearance for the lower front panels.
Front end in lower position.
A 2" section had to be removed from the centre of the nose to align the vertical section of the outer wings. The 3 front nose air intakes will be remodelled.
Leading edge of bonnet opening has been dropped down into the engine bay. The wings will be sectioned and reshaped to close up any gaps.
17 Dec 2012, 10:00pm
WOW! Quite a jiggle but its looking good !
Reckon you could open up the rear arches even more?
Thought you had gone on holiday!
DOUBLE WOW, just seen what else you have done.
Its quite suprising how narrow the originals are.
17 Dec 2012, 10:20pm
Holiday? Nope, my iPhone broke, so no pictures :icon_cry:
18 Dec 2012, 10:01am
Morning Chris ref that cut across the front end could that be the start of a whole *new* project , Geoff King .
4 Jan 2013, 7:48pm
Another day tweaking the TVR 250.
Bulk head and heater ducting were still too high, so marked and trimmed down a little.
An A352 bonnet and it's surround were found to be a remarkably good starting point for the revised 250 bonnet area
Which combined with the original outer wing, shown on the right, give a much higher peak to the wing when compared to the original on the left
With the nose section in its new position the profile of the wing top is all wrong
Now sectioned and lowered, much better :happy:
Bonnet will require a strip adding each side to widen it and the rear of the bulge flattening toward the scuttle area
4 Jan 2013, 10:18pm
I got one of those for Christmas!!
[IMG]http://[/IMG]
4 Jan 2013, 10:20pm
I'm having to make one! No 1:1 scale models available.....yet
5 Jan 2013, 10:13am
Nice camera work with the model.
Queue the scene from Father Ted
That is a big car a long way away, this is a little one close up
At least I hope that is what it is otherwise the guy in the silver one is going to get a hell of a shock when he looks in the rear view mirror and sees the giant hand!
6 Jan 2013, 5:50pm
Ah go on, go on, go on, go on........:lol:
The area between the front arch and headlight was still too big , so pushed the nose back in 50mm
With the tops of both wings re-profiled there is now alot more curves across the front upper surface of the car
11 Jan 2013, 4:53pm
How about.......moving the rear vent fwd and reducing it to something like this?
Apologies for elementary paintshop abilities!:banplease:
11 Jan 2013, 5:10pm
Thankfully i have been watching your thread, otherwise i would be worried about your building abilities...
11 Jan 2013, 8:50pm
11 Jan 2013, 9:12pm
Nicks photoshop, Trib...
16 Jan 2013, 4:12pm
G46 lurker
Hi Tribute guys
Been following your various threads and very impressed. You may have seen my G46 V8 Mk1 threads on the sammio build page (or whatever it's called this week)
I have radically chopped up a G46 and seeing this artificial on the TVR adaptation I am pleased I am following professional methods chop, cut, pin, stitch, glue etc etc.
My question is once you have finalised a special like the TVR do you then generally offer those panels for sale or is that TVR just a one off.
16 Jan 2013, 4:39pm
It seems if anything sits still for a moment Chris will take a mould from it........:laugh:
16 Jan 2013, 5:43pm
Best get my arse moving then don't want him taking a mold of that, need to get on with my build, although its bloody cold outside even for me, three inches of white stuff all over it this morning, now melted and turned to ice. Bonding agent still tacky heat gun being applied and fingers crossed.
16 Jan 2013, 9:06pm
Progress on Alex's car:
Trail bonnet formed and lowered over carb etc
Protruding items will be covered by bonnet bulge
Further chopping/sectioning of the nose was required
New vents cut into front panel, just requires lifting up in the centre to give some curve to the whole area
