Hi all. I thought I'd test the compression on the M50TUB25 engine I'm fitting to my Cabrio before starting to strip the donor - on the basis it might indicate any problems that could be investigated while the engine's on a stand. The numbers are consistent but seem ridiculously high. To the nearest 5psi:
#1 : 225
#2 : 225
#3 : 230
#4 : 220
#5 : 225
#6 : 220
Max values were reached after about 6 strokes in each case. Bentley gives a minimum value range of 142-156psi.
Does this just indicate the tester I bought is poorly calibrated (or crap...)? If so then I suppose the fact the figures don't vary too much is the main thing?
I noticed a little oil had run down into the plug recesses on nos. 3, 4 & 5 cylinders - not enough to form a pool, but certainly enough to need wiping off the bottom of the plug socket. Could this be anything more serious than the cylinder head cover gasket needing replacing?
Mark.
5 Nov 2011, 6:19pm
